Datasheet AD8091, AD8092 (Analog Devices)
DescriptionLow Cost, High Speed Rail-to-Rail Amplifiers
Pages / Page20 / 1 — Low Cost, High Speed. Rail-to-Rail Amplifiers. AD8091/AD8092. FEATURES. …
RevisionC
File Format / SizePDF / 323 Kb
Low Cost, High Speed. Rail-to-Rail Amplifiers. AD8091/AD8092. FEATURES. CONNECTION DIAGRAMS
Datasheet AD8091, AD8092 Analog Devices, Revision: C
Low Cost, High Speed Rail-to-Rail Amplifiers AD8091/AD8092 FEATURES CONNECTION DIAGRAMS Low cost single (AD8091) and dual (AD8092) amplifiers NC 1 AD8091 8 NC Fully specified at +3 V, +5 V, and ±5 V supplies –IN 2 7 +VS Single-supply operation +IN 3 6 VOUT Output swings to within 25 mV of either rail –VS 4 5 NC
1
High speed and fast settling on 5 V
-00 59
NC = NO CONNECT
28
110 MHz, −3 dB bandwidth (G = +1)
0 Figure 1. SOIC-8 (R-8)
145 V/μs slew rate 50 ns settling time to 0.1% AD8091 Good video specifications (G = +2) VOUT 1 5 +VS Gain flatness of 0.1 dB to 20 MHz; RL = 150 Ω –VS 2 0.03% differential gain error; RL = 1 kΩ
-003
+IN 3 4 –IN
59
0.03%differential phase error; R
28
L = 1 kΩ
0
Low distortion
Figure 2. SOT23-5 (RJ-5)
−80 dBc total harmonic @ 1 MHz; RL = 100 Ω Outstanding load drive capability AD8092 OUT1 1 8 +VS Drives 45 mA, 0.5 V from supply rails –IN1 2 7 OUT Drives 50 pF capacitive load (G = +1) +IN1 3 6 –IN2 Low power of 4.4 mA per amplifier –VS 4 5 +IN2
2 00
9- 85
NC = NO CONNECT
02
Coaxial cable drivers
Figure 3. MSOP-8 and SOIC-8 (RM-8, R-8)
Active filters Video switchers Professional cameras CCD imaging systems CDs/DVDs Clock buffers GENERAL DESCRIPTION
The AD8091/AD8092 offer a low power supply current and can operate on a single 3 V power supply. These features are ideally The AD8091 (single) and AD8092 (dual) are low cost, voltage suited for portable and battery-powered applications where size feedback, high speed amplifiers designed to operate on +3 V, and power are critical. +5 V, or ±5 V supplies. The AD8091/AD8092 have true single- supply capability, with an input voltage range extending 200 mV The wide bandwidth and fast slew rate make these amplifiers below the negative rail and within 1 V of the positive rail. useful in many general-purpose, high speed applications where dual power supplies of up to ±6 V and single supplies from +3 Despite their low cost, the AD8091/AD8092 provide excellent V to +12 V are needed. overall performance and versatility. The output voltage swing extends to within 25 mV of each rail, providing the maximum This low cost performance is offered in an 8-lead SOIC output dynamic range with excellent overdrive recovery. This (AD8091/AD8092), a tiny SOT23-5 (AD8091), and an MSOP makes the AD8091/AD8092 useful for video electronics, such (AD8092). as cameras, video switchers, or any high speed portable equip- ment. Low distortion and fast settling make them ideal for active filter applications.
Rev. C Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. rights of third parties that may result from its use. Specifications subject to change without notice. No license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 www.analog.com Trademarks and registered trademarks are the property of their respective owners. Fax: 781.461.3113 ©2002–2007 Analog Devices, Inc. All rights reserved.
Document Outline FEATURES APPLICATIONS CONNECTION DIAGRAMS GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION MAXIMUM POWER DISSIPATION TYPICAL PERFORMANCE CHARACTERISTICS LAYOUT, GROUNDING, AND BYPASSING CONSIDERATIONS POWER SUPPLY BYPASSING GROUNDING INPUT CAPACITANCE INPUT-TO-OUTPUT COUPLING DRIVING CAPACITIVE LOADS OVERDRIVE RECOVERY ACTIVE FILTERS SYNC STRIPPER SINGLE-SUPPLY COMPOSITE VIDEO LINE DRIVER OUTLINE DIMENSIONS ORDERING GUIDE
