Datasheet AD8021 (Analog Devices) - 2
DescriptionLow Noise, High Speed Amplifier for 16-Bit Systems
Pages / Page30 / 2 — AD8021* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. …
RevisionF
File Format / SizePDF / 466 Kb
AD8021* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. COMPARABLE PARTS. REFERENCE DESIGNS. EVALUATION KITS
AD8021* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017 COMPARABLE PARTS REFERENCE DESIGNS EVALUATION KITS
AD8021
View a parametric search of comparable parts. • CN0042 • CN0260
EVALUATION KITS
• Universal Evaluation Board for Single High Speed
REFERENCE MATERIALS
Operational Amplifiers
Product Selection Guide
• High Speed Amplifiers Selection Table
DOCUMENTATION
• SAR ADC & Driver Quick-Match Guide
Application Notes Tutorials
• AN-202: An IC Amplifier User’s Guide to Decoupling, • MT-032: Ideal Voltage Feedback (VFB) Op Amp Grounding, and Making Things Go Right for a Change • MT-033: Voltage Feedback Op Amp Gain and Bandwidth • AN-253: Find Op Amp Noise with Spreadsheet • MT-047: Op Amp Noise • AN-257: Careful Design Tames High Speed Op Amps • MT-048: Op Amp Noise Relationships: 1/f Noise, RMS • AN-356: User's Guide to Applying and Measuring Noise, and Equivalent Noise Bandwidth Operational Amplifier Specifications • MT-049: Op Amp Total Output Noise Calculations for • AN-357: Operational Integrators Single-Pole System • AN-358: Noise and Operational Amplifier Circuits • MT-050: Op Amp Total Output Noise Calculations for • AN-402: Replacing Output Clamping Op Amps with Input Second-Order System Clamping Amps • MT-052: Op Amp Noise Figure: Don't Be Misled • AN-417: Fast Rail-to-Rail Operational Amplifiers Ease • MT-053: Op Amp Distortion: HD, THD, THD + N, IMD, Design Constraints in Low Voltage High Speed Systems SFDR, MTPR • AN-581: Biasing and Decoupling Op Amps in Single • MT-056: High Speed Voltage Feedback Op Amps Supply Applications • MT-058: Effects of Feedback Capacitance on VFB and CFB • AN-649: Using the Analog Devices Active Filter Design Op Amps Tool • MT-059: Compensating for the Effects of Input
Data Sheet
Capacitance on VFB and CFB Op Amps Used in Current-to- • AD8021: Low Noise, High Speed Amplifier for 16-Bit Voltage Converters Systems Data Sheet • MT-060: Choosing Between Voltage Feedback and
User Guides
Current Feedback Op Amps • UG-135: Evaluation Board for Single, High Speed Operational Amplifiers (8-Lead SOIC and Exposed Paddle)
DESIGN RESOURCES
• AD8021 Material Declaration
TOOLS AND SIMULATIONS
• PCN-PDN Information • Analog Filter Wizard • Quality And Reliability • Analog Photodiode Wizard • Symbols and Footprints • OpAmp Error Budget Calculator • Power Dissipation vs Die Temp
DISCUSSIONS
• VRMS/dBm/dBu/dBV calculators View all AD8021 EngineerZone Discussions. • AD8021 SPICE Macro-Model
SAMPLE AND BUY
Visit the product page to see pricing options. Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION CONNECTION DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS MAXIMUM POWER DISSIPATION ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS APPLICATIONS USING THE DISABLE FEATURE THEORY OF OPERATION PCB LAYOUT CONSIDERATIONS DRIVING 16-BIT ADCs DIFFERENTIAL DRIVER USING THE AD8021 IN ACTIVE FILTERS DRIVING CAPACITIVE LOADS OUTLINE DIMENSIONS ORDERING GUIDE
