Datasheet OP777, OP727, OP747 (Analog Devices) - 4
DescriptionPrecision Micropower Single-Supply Operational Amplifiers
Pages / Page16 / 4 — OP777/OP727/OP747. ABSOLUTE MAXIMUM RATINGS1, 2. Package Type. Unit. …
RevisionD
File Format / SizePDF / 210 Kb
OP777/OP727/OP747. ABSOLUTE MAXIMUM RATINGS1, 2. Package Type. Unit. CAUTION. WARNING!. ESD SENSITIVE DEVICE
OP777/OP727/OP747 ABSOLUTE MAXIMUM RATINGS1, 2 Package Type Unit CAUTION WARNING! ESD SENSITIVE DEVICE
OP777/OP727/OP747 ABSOLUTE MAXIMUM RATINGS1, 2 Package Type 3 JA JC Unit
Supply Voltage . 36 V Input Voltage . –V 8-Lead MSOP (RM) 190 44 °C/W S – 5 V to +VS + 5 V Differential Input Voltage . ± Supply Voltage 8-Lead SOIC (R) 158 43 °C/W Output Short-Circuit Duration to GND . Indefinite 8-Lead TSSOP (RU) 240 43 °C/W Storage Temperature Range 14-Lead SOIC (R) 120 36 °C/W RM, R, RU Packages . –65°C to +150°C 14-Lead TSSOP (RU) 180 35 °C/W Operating Temperature Range NOTES OP777/OP727/OP747 . –40°C to +85°C 1Absolute maximum ratings apply at 25°C, unless otherwise noted. Junction Temperature Range 2Stresses above those listed under Absolute Maximum Ratings may cause perma- RM, R, RU Packages . –65°C to +150°C nent damage to the device. This is a stress rating only; functional operation of the device at these or any other conditions above those listed in the operational Lead Temperature Range (Soldering, 60 sec) . 300°C sections of this specification is not implied. Exposure to absolute maximum rating Electrostatic Discharge (Human Body Model) . 2000 V max conditions for extended periods may affect device reliability. 3θJA is specified for worst-case conditions, i.e., θJA is specified for device soldered in circuit board for surface-mount packages.
CAUTION
ESD (electrostatic discharge) sensitive device. Electrostatic charges as high as 4000 V readily
WARNING!
accumulate on the human body and test equipment and can discharge without detection. Although the OP777/OP727/OP747 features proprietary ESD protection circuitry, permanent damage may occur on devices subjected to high-energy electrostatic discharges. Therefore, proper ESD
precautions are recommended to avoid performance degradation or loss of functionality. –4– REV. D Document Outline GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAMS SIMILAR LOW POWER PRODUCTS ELECTRICAL CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS Typical Performance Characteristics BASIC OPERATION OUTLINE DIMENSIONS ORDERING GUIDE REVISION HISTORY
