Datasheet AD8024 (Analog Devices) - 3
DescriptionQuad 350 MHz 24 V Amplifier
Pages / Page13 / 3 — AD8024–SPECIFICATIONS (@ TA = 25. C, VS =. 7.5 V, CLOAD = 10 pF, RL = …
RevisionC
File Format / SizePDF / 197 Kb
AD8024–SPECIFICATIONS (@ TA = 25. C, VS =. 7.5 V, CLOAD = 10 pF, RL = 150. , unless otherwise noted.) Model. Conditions. Min. Typ
AD8024–SPECIFICATIONS (@ TA = 25 C, VS = 7.5 V, CLOAD = 10 pF, RL = 150 , unless otherwise noted.) Model Conditions Min Typ
AD8024–SPECIFICATIONS (@ TA = 25 C, VS = 7.5 V, CLOAD = 10 pF, RL = 150 , unless otherwise noted.) Model Conditions Min Typ Max Unit
DYNAMIC PERFORMANCE Bandwidth (3 dB) RFB = 800 Ω, No Peaking, G = +3 160 200 MHz Bandwidth (0.1 dB) No Peaking, G = +3 25 MHz Slew Rate 6 V Step, G = +3, CLOAD = 300 pF 370 390 V/µs Settling Time to 0.1% TA = 25°C to 85°C, ± 3 V (6 V Step) 30 ns CLOAD = 300 pF, RS = 10.5 Ω, RLOAD > 1 kΩ, RFB = 2.32 kΩ ±1 V (2 V Step), CLOAD = 5 pF, 18 ns RS = 0 Ω, RLOAD > 1 kΩ, RFB = 750 kΩ NOISE/HARMONIC PERFORMANCE Total Harmonic Distortion fC = 5 MHz, RL = 1 kΩ –72 dBc fC = 5 MHz, RL = 150 Ω –67 dBc Input Voltage Noise f = 10 kHz 3 nV/√Hz Input Current Noise f = 10 kHz (–IIN) 8 pA/√Hz Differential Gain (RL = 150 Ω) f = 3.58 MHz, G = +2 0.04 % Differential Phase (RL = 150 Ω) f = 3.58 MHz, G = +2 0.09 Degrees DC PERFORMANCE Input Offset Voltage TMIN to TMAX 2 5 mV Offset Drift 1.5 µV/°C +Input Bias Current 1 7.5 µA –Input Bias Current 1 3 µA Open-Loop Transresistance 0.850 1.2 MΩ TMIN to TMAX 0.840 MΩ INPUT CHARACTERISTICS Input Resistance +Input TMIN to TMAX 1 MΩ –Input TMIN to TMAX 135 Ω Input Capacitance 2 pF Input Common-Mode Voltage –VS + 1.2 +VS – 2 V Common-Mode Rejection Ratio Input Offset Voltage 62 66 dB –Input Current 0.2 µA/V +Input Current 1 µA/V OUTPUT CHARACTERISTICS Output Voltage Swing RL = 1 kΩ VOL – VEE 0.8 1.0 V VCC – VOH 1.1 1.3 V RL = 150 Ω VOL – VEE 1.0 1.35 V VCC – VOH 1.3 1.55 V Linear Output Current Error <3%, R1 = 50 Ω 35 50 mA Max Dynamic Output Current 300 mA Capacitive Load Drive 1000 pF MATCHING CHARACTERISTICS Dynamic Crosstalk (Worst Between Any 2) G = +2, f = 5 MHz –58 dB DC Input Offset Voltage Match 0.4 1.5 mV Input Current Match 0.1 2.0 µA POWER SUPPLY Operating Range Single Supply 5 24 V Dual Supply ±2.5 ±12 V Total Quiescent Current 16 17 mA TMIN to TMAX 19.5 mA Disable = HIGH 0.5 1 mA Power Supply Rejection Ratio Input Offset Voltage VS = ± 6.5 V to ± 8.5 V 64 70 dB –Input Current 0.03 µA/V +Input Current 0.07 µA/V –2– REV. C
