Datasheet AD8016 (Analog Devices) - 2
DescriptionFull Rate ADSL Line Driver With Powerdown
Pages / Page21 / 2 — AD8016* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. …
RevisionC
File Format / SizePDF / 517 Kb
AD8016* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. COMPARABLE PARTS. DESIGN RESOURCES. DOCUMENTATION
AD8016* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017 COMPARABLE PARTS DESIGN RESOURCES DOCUMENTATION
AD8016
View a parametric search of comparable parts. • AD8016 Material Declaration • PCN-PDN Information
DOCUMENTATION
• Quality And Reliability
Application Notes
• Symbols and Footprints • AN-649: Using the Analog Devices Active Filter Design Tool
DISCUSSIONS
• AN-692: Universal Precision Op Amp Evaluation Board View all AD8016 EngineerZone Discussions.
Data Sheet
• AD8016: Low Power, High Output Current xDSL Line
SAMPLE AND BUY
Driver Data Sheet Visit the product page to see pricing options.
TOOLS AND SIMULATIONS TECHNICAL SUPPORT
• AD8016 SPICE Macro-Model Submit a technical question or find your regional support number.
REFERENCE MATERIALS Tutorials DOCUMENT FEEDBACK
• MT-034: Current Feedback (CFB) Op Amps Submit feedback for this data sheet. • MT-051: Current Feedback Op Amp Noise Considerations • MT-057: High Speed Current Feedback Op Amps • MT-059: Compensating for the Effects of Input Capacitance on VFB and CFB Op Amps Used in Current-to- Voltage Converters
Document Outline Features Pin Configurations General Description Revision History Specifications Logic Inputs (CMOS Compatible Logic) Absolute Maximum Ratings Maximum Power Dissipation ESD Caution Pin Configurations and Function Descriptions Typical Performance Characteristics Test Circuts Theory of Operation Power Supply and Decoupling Feedback Resistor Selection Bias Pin and PWDN Features Thermal Shutdown Applications Information Multitone Power Ratio (MTPR) Generating DMT Power Dissipation Thermal Enhancements and PCB Layout Thermal Testing Air Flow Test Conditions DUT Power Thermal Resistance PCB Dimensions of a Differential Driver Circuit Experimental Results Outline Dimensions Ordering Guide
