20 /9 — AD8541/AD8542/AD8544. VS = 2.7V. VS = 5V. RL = 2kΩ. TA = 25°C. AV = 1. A …
Revision
G
PDF / 317 Kb
AD8541/AD8542/AD8544. VS = 2.7V. VS = 5V. RL = 2kΩ. TA = 25°C. AV = 1. A = 25°C. ION. T C JE. 1.35V. R E. -M ON. M OM. 500mV. 10µs. –10. 10k. 100k. 10M
AD8541/AD8542/AD854490VS = 2.7VVS = 5VRL = 2kΩ80TA = 25°CAV = 1)TBA = 25°Cd70(ION60T C JE50E1.35VR E40OD30-M ON20M OM10C 17 0 0500mV10µs 5- 93 00 –10 20 1k10k100k1M10M 0 5- FREQUENCY (Hz) 93 00 Figure 17. Large Signal Transient Response Figure 20. Common-Mode Rejection vs. Frequency 5VS = 2.7VVS = 5VRL = NO LOAD4RL = NO LOADTA = 25°CTA = 25°C380(mV) E2G)A6045rees)BT1degL(DIN 4090( TVO0TGAIF20135HSESF –1FE0180O T –2HAS PPU IN –3–4 40 0 5- 93 8 –5 00 1k10k100k1M10M 01 5- 00.51.01.52.02.53.03.54.04.55.0FREQUENCY (Hz) 93 00 COMMON-MODE VOLTAGE (V) Figure 18. Open-Loop Gain and Phase vs. Frequency Figure 21. Input Offset Voltage vs. Common-Mode Voltage 16010kVVS = 5VS = 5VB) 140TdTA = 25°CA = 25°C(1kIO 120T)AV100mN R( E 100IO80–PSRRCTAG TSOURCEJEL60+PSRRO10REVY L40UTSINKPPP1U20UT OR S∆E0W0.1O P –20–40 9 0.01 1 2 1001k10k100k1M10M 01 0.0010.010.1110100 0 5- 5- FREQUENCY (Hz) 93 LOAD CURRENT (mA) 93 00 00 Figure 19. Power Supply Rejection Ratio vs. Frequency Figure 22. Output Voltage to Supply Rail vs. Load Current Rev. G | Page 9 of 20 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION PIN CONFIGURATIONS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION NOTES ON THE AD854X AMPLIFIERS Lower Supply Current for 1 MHz Gain Bandwidth Higher Output Current Better Performance at Lower Voltages APPLICATIONS NOTCH FILTER COMPARATOR FUNCTION PHOTODIODE APPLICATION OUTLINE DIMENSIONS ORDERING GUIDE AUTOMOTIVE PRODUCTS
