Datasheet AD8017 (Analog Devices) - 10
DescriptionLow Cost, High Output Current, High Output Voltage Line Driver
Pages / Page17 / 10 — AD8017. +20. 120. 100. –20. pF –. dBm –. –40. POWER. CAP LOAD 40. –60. …
RevisionC
File Format / SizePDF / 262 Kb
AD8017. +20. 120. 100. –20. pF –. dBm –. –40. POWER. CAP LOAD 40. –60. –80. 150. FREQUENCY – kHz. SERIES RESISTANCE –. –10. –PSRR. –30. dB –. –50. +PSRR
AD8017 +20 120 100 –20 pF – dBm – –40 POWER CAP LOAD 40 –60 –80 150 FREQUENCY – kHz SERIES RESISTANCE – –10 –PSRR –30 dB – –50 +PSRR
AD8017 +20 120 100 0 80 –20 pF – dBm – 60 –40 POWER CAP LOAD 40 –60 20 –80 0 0 50 100 150 0 2 4 6 8 FREQUENCY – kHz SERIES RESISTANCE –
⍀ TPC 23. Multitone Power Ratio: VS = ±6 V, 13 dBm TPC 26. RS and CL vs. 30% Overshoot Output Power into 25 Ω
0 0 –10 –10 –20 –20 –PSRR –30 –30 –40 dB – dB – –50 –40 +PSRR CMRR –60 PSRR –50 –70 –60 –80 –70 –90 –100 –80 0.1 1 10 100 1000 0.1 1 10 100 1000 FREQUENCY – MHz FREQUENCY – MHz
TPC 24. CMRR vs. Frequency; VS = ±6 V or VS = ±2.5 V TPC 27. PSRR vs. Frequency; VS = ±6 V or VS = ±2.5 V
0.4 12 1000 180 10 Hz Hz 0.3
PHASE nA/ nA/ k 8 – 100 120 Degrees 0.2 6 i TRANSIMPEDANCE N eN 4 10 60 PHASE 0.1 TRANSIMPEDANCE INPUT CURRENT NOISE 2 INPUT VOLTAGE NOISE 0 0 1 0 0.01 0.1 1 10 100 0.001 0.01 0.1 1 10 100 1000 FREQUENCY – kHz FREQUENCY – MHz
TPC 25. Noise vs. Frequency TPC 28. Open-Loop Transimpedance and Phase vs. Frequency REV. C –9–
