AD825* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017COMPARABLE PARTSREFERENCE MATERIALS View a parametric search of comparable parts. Tutorials • MT-032: Ideal Voltage Feedback (VFB) Op Amp EVALUATION KITS • MT-033: Voltage Feedback Op Amp Gain and Bandwidth • Universal Evaluation Board for Single High Speed • MT-047: Op Amp Noise Operational Amplifiers • MT-048: Op Amp Noise Relationships: 1/f Noise, RMS Noise, and Equivalent Noise Bandwidth DOCUMENTATION • MT-049: Op Amp Total Output Noise Calculations for Application Notes Single-Pole System • AN-108: JFET-Input Amps are Unrivaled for Speed and • MT-050: Op Amp Total Output Noise Calculations for Accuracy Second-Order System • AN-214: Ground Rules for High Speed Circuits • MT-052: Op Amp Noise Figure: Don't Be Misled • AN-356: User's Guide to Applying and Measuring • MT-053: Op Amp Distortion: HD, THD, THD + N, IMD, Operational Amplifier Specifications SFDR, MTPR • AN-402: Replacing Output Clamping Op Amps with Input • MT-056: High Speed Voltage Feedback Op Amps Clamping Amps • MT-058: Effects of Feedback Capacitance on VFB and CFB • AN-417: Fast Rail-to-Rail Operational Amplifiers Ease Op Amps Design Constraints in Low Voltage High Speed Systems • MT-060: Choosing Between Voltage Feedback and • AN-581: Biasing and Decoupling Op Amps in Single Current Feedback Op Amps Supply Applications • AN-649: Using the Analog Devices Active Filter Design DESIGN RESOURCES Tool • AD825 Material Declaration Data Sheet • PCN-PDN Information • AD825: Low Cost, General-Purpose High Speed JFET • Quality And Reliability Amplifier Data Sheet • Symbols and Footprints User Guides • UG-755: 8-Lead SOIC Amplifier Evaluation Board User DISCUSSIONS Guide View all AD825 EngineerZone Discussions. TOOLS AND SIMULATIONSSAMPLE AND BUY • Analog Filter Wizard • Analog Photodiode Wizard Visit the product page to see pricing options. • Power Dissipation vs Die Temp TECHNICAL SUPPORT • VRMS/dBm/dBu/dBV calculators Submit a technical question or find your regional support • AD825 SPICE Macro-Model number. DOCUMENT FEEDBACK Submit feedback for this data sheet. This page is dynamically generated by Analog Devices, Inc., and inserted into this data sheet. A dynamic change to the content on this page will not trigger a change to either the revision number or the content of the product data sheet. This dynamic page may be frequently modified. Document Outline Features Applications Connection Diagrams General Description Table of Contents Revision History Specifications Absolute Maximum Ratings Pin Configurations ESD Caution Typical Performance Characteristics Driving Capacitive Loads Theory of Operation Input Consideration Grounding and Bypassing Second-Order Low-Pass Filter Outline Dimensions Ordering Guide
