Datasheet AD8012 (Analog Devices) - 3
Description | Dual 350 MHz Low Power Amplifier |
Pages / Page | 17 / 3 — AD8012–SPECIFICATIONS. DUAL SUPPLY (@ TA = 25. C, VS =. 5 V, G = +2, RL = … |
Revision | C |
File Format / Size | PDF / 284 Kb |
AD8012–SPECIFICATIONS. DUAL SUPPLY (@ TA = 25. C, VS =. 5 V, G = +2, RL = 100. , RF = RG = 750
AD8012–SPECIFICATIONS DUAL SUPPLY (@ TA = 25 C, VS = 5 V, G = +2, RL = 100 , RF = RG = 750 , unless otherwise noted.) Parameter Conditions Min Typ Max Unit
DYNAMIC PERFORMANCE –3 dB Small Signal Bandwidth G = +1, VOUT < 0.4 V p-p, RL = 1 kΩ 270 350 MHz G = +2, VOUT < 0.4 V p-p, RL = 1 kΩ 95 150 MHz G = +2, VOUT < 0.4 V p-p, RL = 100 Ω 90 MHz 0.1 dB Bandwidth VOUT < 0.4 V p-p, RL = 1 kΩ/100 Ω 40/23 MHz Large Signal Bandwidth VOUT = 4 V p-p 75 MHz Slew Rate VOUT = 4 V p-p 2,250 V/µs Rise and Fall Time VOUT = 2 V p-p 3 ns Settling Time 0.1%, VOUT = 2 V p-p 20 ns 0.02%, VOUT = 2 V p-p 35 ns Overdrive Recovery 2⫻ Overdrive 60 ns NOISE/HARMONIC PERFORMANCE Distortion VOUT = 2 V p-p, G = +2 Second Harmonic 500 kHz, RL = 1 kΩ/100 Ω –89/–73 dBc 5 MHz, RL = 1 kΩ/100 Ω –78/–62 dBc Third Harmonic 500 kHz, RL = 1 kΩ/100 Ω –84/–72 dBc 5 MHz, RL = 1 kΩ/100 Ω –66/–52 dBc Output IP3 500 kHz, ∆f = 10 kHz, RL = 1 kΩ/100 Ω 30/40 dBm IMD 500 kHz, ∆f = 10 kHz, RL = 1 kΩ/100 Ω –79/–77 dBc Crosstalk 5 MHz, RL = 100 Ω –70 dB Input Voltage Noise f = 10 kHz 2.5 nV/√Hz Input Current Noise f = 10 kHz, +Input, –Input 15 pA/√Hz Differential Gain f = 3.58 MHz, RL = 150 Ω/1 kΩ, G = +2 0.02/0.02 % Differential Phase f = 3.58 MHz, RL = 150 Ω/1 kΩ, G = +2 0.3/0.06 Degrees DC PERFORMANCE Input Offset Voltage ±1.5 ±4 mV T ± MIN–TMAX 5 mV Open-Loop Transimpedance VOUT = ± 2 V, RL = 100 Ω 240 500 kΩ TMIN–TMAX 200 kΩ INPUT CHARACTERISTICS Input Resistance +Input 450 kΩ Input Capacitance +Input 2.3 pF Input Bias Current +Input, –Input ±3 ±12 µA +Input, –Input, TMIN–TMAX ±15 µA Common-Mode Rejection Ratio VCM = ± 2.5 V –56 –60 dB Input Common-Mode Voltage Range ±3.8 ±4.1 V OUTPUT CHARACTERISTICS Output Resistance G = +2 0.1 Ω Output Voltage Swing ±3.85 ±4 V Output Current TMIN–TMAX 70 125 mA Short-Circuit Current 500 mA POWER SUPPLY Supply Current/Amp 1.7 1.8 mA TMIN–TMAX 1.9 mA Operating Range Dual Supply ±1.5 ±6.0 V Power Supply Rejection Ratio –58 –60 dB Specifications subject to change without notice. –2– REV. B Document Outline FEATURES APPLICATIONS PRODUCT DESCRIPTION FUNCTIONAL BLOCK DIAGRAM SPECIFICATIONS DUAL SUPPLY SINGLE SUPPLY MAXIMUM POWER DISSIPATION Test Circuits ABSOLUTE MAXIMUM RATINGS ORDERING GUIDE Typical Performance Characteristics THEORY OF OPERATION DC GAIN CHARACTERISTICS APPLICATIONS Line Driving for HDSL Choosing the Appropriate Turns Ratio for the Transformer LAYOUT CONSIDERATIONS OUTLINE DIMENSIONS Revision History
