Datasheet OP281, OP481 (Analog Devices) - 6
DescriptionUltralow Power, Rail-to-Rail Output Operational Amplifiers
Pages / Page20 / 6 — OP281/OP481. ABSOLUTE MAXIMUM RATINGS. THERMAL RESISTANCE. Table 4. …
RevisionD
File Format / SizePDF / 400 Kb
OP281/OP481. ABSOLUTE MAXIMUM RATINGS. THERMAL RESISTANCE. Table 4. Parameter Rating. Table 5. Thermal Resistance. Package Type
OP281/OP481 ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE Table 4 Parameter Rating Table 5 Thermal Resistance Package Type
link to page 6
OP281/OP481 ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE Table 4. Parameter Rating Table 5. Thermal Resistance
Supply Voltage 16 V
Package Type θ 1 JA θJC Unit
Input Voltage GND to VS + 10 V 8-Lead SOIC (R Suffix) 158 43 °C/W Differential Input Voltage ±3.5 V 8-Lead TSSOP (RU Suffix) 240 43 °C/W Output Short-Circuit Duration to GND Indefinite 14-Lead SOIC (R Suffix) 120 36 °C/W Storage Temperature Range −65°C to +150°C 14-Lead TSSOP (RU Suffix) 240 43 °C/W Operating Temperature Range −40°C to +85°C 1 Junction Temperature Range −65°C to +150°C θJA is specified for the worst-case conditions, that is, θJA is specified for device soldered in circuit board for TSSOP and SOIC packages. Lead Temperature Range (Soldering, 60 sec) 300°C
ESD CAUTION
Stresses above those listed under Absolute Maximum Ratings may cause permanent damage to the device. This is a stress rating only; functional operation of the device at these or any other conditions above those indicated in the operational section of this specification is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. Rev. D | Page 6 of 20 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION PIN CONFIGURATIONS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS APPLICATIONS THEORY OF OPERATION INPUT OVERVOLTAGE PROTECTION INPUT OFFSET VOLTAGE INPUT COMMON-MODE VOLTAGE RANGE CAPACITIVE LOADING MICROPOWER REFERENCE VOLTAGE GENERATOR WINDOW COMPARATOR LOW-SIDE CURRENT MONITOR LOW VOLTAGE HALF-WAVE AND FULL-WAVE RECTIFIERS BATTERY-POWERED TELEPHONE HEADSET AMPLIFIER OUTLINE DIMENSIONS ORDERING GUIDE
