Datasheet OP184, OP284, OP484 (Analog Devices) - 8
DescriptionSingle-Supply Rail-to-Rail Input/Output Operational Amplifier
Pages / Page24 / 8 — OP184/OP284/OP484. 500. 1.50. VS = ±15V. 400. A = 25°C. mA). 1.25. 300. R …
RevisionJ
File Format / SizePDF / 685 Kb
OP184/OP284/OP484. 500. 1.50. VS = ±15V. 400. A = 25°C. mA). 1.25. 300. R (. 200. 1.00. 100. R AM. 0.75. CURRE. –100. 0.50. UT –200. INP. –300. L P. 0.25. –400. –500
OP184/OP284/OP484 500 1.50 VS = ±15V 400 A = 25°C mA) 1.25 300 R ( 200 1.00 100 R AM 0.75 CURRE –100 0.50 UT –200 INP –300 L P 0.25 –400 –500
OP184/OP284/OP484 500 1.50 VS = ±15V T 400 A = 25°C mA) 1.25 300 R ( A) IE n 200 IF ( L 1.00 P NT 100 R AM 0 E 0.75 CURRE /P AS NT –100 BI 0.50 UT –200 CURRE INP Y –300 L P 0.25 UP –400
011
S
014
–500
00293-
0
00293-
–15 –10 –5 0 5 10 15 0 ±2.5 ±5.0 ±7.5 ±10.0 ±12.5 ±15.0 ±17.5 ±20.0 COMMON-MODE VOLTAGE (V) SUPPLY VOLTAGE (V)
Figure 11. Input Bias Current vs. Common-Mode Voltage Figure 14. Supply Current vs. Supply Voltage
1000 50 VS = ±15V VS = ±15V 40 ) mA) V ( +ISC m ( NT GE 30 SOURCE –ISC 100 CURRE –I OLTA T SC T V U 20 RCUI TP -CI SINK +ISC OU RT HO 10 S VS = +5V, VCM = +2.5V
012 015
10
00293-
0
00293-
0.01 0.1 1 10 –50 –25 0 25 50 75 100 125 LOAD CURRENT (mA) TEMPERATURE (°C)
Figure 12. Output Voltage to Supply Rail vs. Load Current Figure 15. Short-Circuit Current vs. Temperature
1.2 70 VS = 5V 60 TA = 25°C 1.1 NO LOAD mA) 50 VS = ±15V R ( ) 1.0 IE 40 0 dB IF ( rees) L P IN 30 45 0.9 Deg ( /AM GA T 20 90 F NT HI 0.8 S V -LOOP 10 135 S = +5V N E E CURRE 0 180 Y 0.7 OP HAS L P P VS = +3V –10 225 UP S 0.6
013
–20 270
016
0.5
00293-
–30
00293-
–40 25 85 125 10k 100k 1M 10M TEMPERATURE (°C) FREQUENCY (Hz)
Figure 13. Supply Current vs. Temperature Figure 16. Open-Loop Gain and Phase vs. Frequency (No Load) Rev. J | Page 8 of 24 Document Outline Features Applications General Description Pin Configurations Table of Contents Revision History Specifications Electrical Characteristics Absolute Maximum Ratings Thermal Resistance ESD Caution Typical Performance Characteristics Applications Information Functional Description Input Overvoltage Protection Output Phase Reversal Designing Low Noise Circuits in Single-Supply Applications Overdrive Recovery Single-Supply, 3 V Instrumentation Amplifier 2.5 V Reference from a 3 V Supply 5 V Only, 12-Bit DAC Swings Rail-to-Rail High-Side Current Monitor Capacitive Load Drive Capability Low Dropout Regulator with Current Limiting 3 V, 50 Hz/60 Hz Active Notch Filter with False Ground Outline Dimensions Ordering Guide
