Datasheet AD8079 (Analog Devices) - 2
DescriptionDual 260 MHz Gain = +2.0 & +2.2 Buffer
Pages / Page14 / 2 — AD8079* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. …
File Format / SizePDF / 389 Kb
AD8079* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. COMPARABLE PARTS. REFERENCE MATERIALS
AD8079* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017 COMPARABLE PARTS REFERENCE MATERIALS
AD8079
View a parametric search of comparable parts.
Product Selection Guide
• High Speed Amplifiers Selection Table
DOCUMENTATION Tutorials Application Notes
• MT-032: Ideal Voltage Feedback (VFB) Op Amp • AN-356: User's Guide to Applying and Measuring • MT-033: Voltage Feedback Op Amp Gain and Bandwidth Operational Amplifier Specifications • MT-047: Op Amp Noise • AN-402: Replacing Output Clamping Op Amps with Input • MT-048: Op Amp Noise Relationships: 1/f Noise, RMS Clamping Amps Noise, and Equivalent Noise Bandwidth • AN-417: Fast Rail-to-Rail Operational Amplifiers Ease • MT-049: Op Amp Total Output Noise Calculations for Design Constraints in Low Voltage High Speed Systems Single-Pole System • AN-581: Biasing and Decoupling Op Amps in Single • MT-050: Op Amp Total Output Noise Calculations for Supply Applications Second-Order System • AN-649: Using the Analog Devices Active Filter Design • MT-052: Op Amp Noise Figure: Don't Be Misled Tool • MT-053: Op Amp Distortion: HD, THD, THD + N, IMD,
Data Sheet
SFDR, MTPR • AD8079: Dual 260 MHz Gain = +2.0 & +2.2 Buffer Data • MT-056: High Speed Voltage Feedback Op Amps Sheet • MT-058: Effects of Feedback Capacitance on VFB and CFB Op Amps
TOOLS AND SIMULATIONS
• MT-059: Compensating for the Effects of Input • Power Dissipation vs Die Temp Capacitance on VFB and CFB Op Amps Used in Current-to- • VRMS/dBm/dBu/dBV calculators Voltage Converters • AD8079 SPICE Macro-Model • MT-060: Choosing Between Voltage Feedback and Current Feedback Op Amps
DESIGN RESOURCES
• AD8079 Material Declaration • PCN-PDN Information • Quality And Reliability • Symbols and Footprints
DISCUSSIONS
View all AD8079 EngineerZone Discussions.
SAMPLE AND BUY
Visit the product page to see pricing options.
TECHNICAL SUPPORT
Submit a technical question or find your regional support number.
