Datasheet AD8031, AD8032 (Analog Devices)
Description | 2.7 V, 800 μA, 80 MHz Rail-to-Rail I/O Amplifiers |
Pages / Page | 20 / 1 — 2.7 V, 800 μA, 80 MHz. Rail-to-Rail I/O Amplifiers. Data Sheet. AD8031/. … |
Revision | G |
File Format / Size | PDF / 422 Kb |
2.7 V, 800 μA, 80 MHz. Rail-to-Rail I/O Amplifiers. Data Sheet. AD8031/. AD8032. FEATURES. CONNECTION DIAGRAMS. Low power. NC 1. 8 NC
2.7 V, 800 μA, 80 MHz Rail-to-Rail I/O Amplifiers Data Sheet AD8031/ AD8032 FEATURES CONNECTION DIAGRAMS Low power NC 1 8 NC OUT1 1 AD8032 8 +VS Supply current 800 μA/amplifier –IN 2 – 7 +VS –IN1 2 7 OUT2 – + Fully specified at +2.7 V, +5 V, and ±5 V supplies +IN 3 + 6 OUT +IN1 3 6 –IN2 + –
02
–V
0
S 4 AD8031 5 NC –V 5 +IN2
6-
High speed and fast settling on 5 V
-001
S 4
05
NC = NO CONNECT
01
80 MHz, −3 dB bandwidth (G = +1)
01056 Figure 1. 8-Lead PDIP (N) and Figure 2. 8-Lead PDIP (N),
30 V/μs slew rate
SOIC_N (R) SOIC_N (R), and MSOP (RM)
125 ns settling time to 0.1% Rail-to-rail input and output AD8031 VOUT 1 5 +VS No phase reversal with input 0.5 V beyond supplies –V Input CMVR extends beyond rails by 200 mV S 2 + –
3
Output swing to within 20 mV of either rail +IN 3 4 –IN
-00 6 05
Low distortion
01 Figure 3. 5-Lead SOT-23 (RJ-5)
−62 dB @ 1 MHz, VO = 2 V p-p −86 dB @ 100 kHz, V O = 4.6 V p-p Output current: 15 mA
Operating on supplies from +2.7 V to +12 V and dual supplies
High grade option: VOS (maximum) = 1.5 mV
up to ±6 V, the AD8031/AD8032 are ideal for a wide range of applications, from battery-operated systems with large bandwidth
requirements to high speed systems where component density
High speed, battery-operated systems
requires lower power dissipation. The AD8031/AD8032 are
High component density systems
available in 8-lead PDIP and 8-lead SOIC_N packages and operate over the industrial temperature range of −40°C to
Portable test instruments
+85°C. The AD8031A is also available in the space-saving
A/D buffers
5-lead SOT-23 package, and the AD8032A is available in an
Active filters
8-lead MSOP package.
High speed, set-and-demand amplifiers VIN = 4.85V p-p VOUT = 4.65V p-p G = +1 GENERAL DESCRIPTION
The AD8031 (single) and AD8032 (dual) single-supply, voltage
IV IV /D /D
feedback amplifiers feature high speed performance with
1V 1V
80 MHz of small signal bandwidth, 30 V/μs slew rate, and 125 ns settling time. This performance is possible while consuming less than 4.0 mW of power from a single 5 V supply. These features 4 00 6- 6-005
2µs/DIV
05
2µs/DIV
05 increase the operation time of high speed, battery-powered 01 01 Figure 4. Input VIN Figure 5. Output VOUT systems without compromising dynamic performance.
+5V
The products have true single-supply capability with rail-to-rail
input and output characteristics and are specified for +2.7 V, +5 V,
VOUT VIN +
6 and ±5 V supplies. The input voltage range can extend to 500 mV
1kΩ 1.7pF
00 6-
+2.5V
05 beyond each rail. The output voltage swings to within 20 mV of 01 each rail providing the maximum output dynamic range. Figure 6. Rail-to-Rail Performance at 100 kHz The AD8031/AD8032 also offer excellent signal quality for only 800 μA of supply current per amplifier; THD is −62 dBc with a 2 V p-p, 1 MHz output signal, and –86 dBc for a 100 kHz, 4.6 V p-p signal on +5 V supply. The low distortion and fast settling time make them ideal as buffers to single-supply ADCs.
Rev. G Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2014 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline Features Applications General Description Connection Diagrams Table of Contents Revision History Specifications +2.7 V Supply +5 V Supply ±5 V Supply Absolute Maximum Ratings Maximum Power Dissipation ESD Caution Typical Performance Characteristics Theory of Operation Input Stage Operation Overdriving the Input Stage Output Stage, Open-Loop Gain and Distortion vs. Clearance from Power Supply Output Overdrive Recovery Driving Capacitive Loads Applications A 2 MHz Single-Supply, Biquad Band-Pass Filter High Performance, Single-Supply Line Driver Outline Dimensions Ordering Guide
