Datasheet AD815 (Analog Devices) - 6 Manufacturer Analog Devices Description High Output Current Differential Driver Pages / Page 16 / 6 — AD815. TA = 25. VS =. 15V. 10V. V I N. 1/2. RTI OFFSET – mV. f = 0.1Hz … Revision D File Format / Size PDF / 589 Kb Document Language English
AD815. TA = 25. VS =. 15V. 10V. V I N. 1/2. RTI OFFSET – mV. f = 0.1Hz 100. –10. –20. VOUT. 49.9. INPUT OFFSET VOLTAGE – mV. S =. RL =. –12. –40. –14. –60. 100
Model Line for this Datasheet Text Version of Document AD815 0 80 TA = 25 ⴗC –2 60 VS = ⴞ15V –4 40 VS = ⴞ5V VS = ⴞ10V –6 20 VS = ⴞ5V –8 0 V I N 1/2 RTI OFFSET – mV f = 0.1Hz 100 ⍀AD815 –10 –20 VOUT V 49.9 ⍀INPUT OFFSET VOLTAGE – mV S = ⴞ15V RL = –12 –40 5 ⍀1k ⍀1k ⍀–14 –60 –40 –20 0 20 40 60 80 100 –2.0 –1.6 –1.2 –0.8 –0.4 0 0.4 0.8 1.2 1.6 2.0 JUNCTION TEMPERATURE – ⴗC LOAD CURRENT – Amps Figure 10. Input Offset Voltage vs. Temperature Figure 13. Thermal Nonlinearity vs. Output Current Drive750 VS = ⴞ15V ⍀100 700 SOURCE 10 650 VS = ⴞ5V 600 1 VS = ⴞ15V SINK 550 0.1 SHORT CIRCUIT CURRENT – mA 500 CLOSED-LOOP OUTPUT RESISTANCE – 0.01 450 –60 –40 –20 0 20 40 60 80 100 120 140 30k 100k 300k 1M 3M 10M 30M 100M 300M JUNCTION TEMPERATURE – ⴗC FREQUENCY – Hz Figure 11. Short Circuit Current vs. Temperature Figure 14. Closed-Loop Output Resistance vs. Frequency15 T V A = 25 ⴗC T S = ⴞ10V 40 A = 25 ⴗC V 10 S = ±15V RL = 25 ⍀VS = ⴞ5V VS = ⴞ15V RL = 100 ⍀5 30 0 RL = 50 ⍀20 V I N 1/2 RTI OFFSET – mV f = 0.1Hz –5 100 ⍀AD815 V R OUT L = 25 ⍀49.9 ⍀R 10 L = –10 25 ⍀1k ⍀1k ⍀DIFFERENTIAL OUTPUT VOLTAGE – V p-p RL = 1 ⍀–15 0 –20 –16 –12 –8 –4 0 4 8 12 16 20 0 2 4 6 8 10 12 14 FREQUENCY – MHz VOUT – Volts Figure 12. Gain Nonlinearity vs. Output Voltage Figure 15. Large Signal Frequency Response REV. D –5– Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS PIN CONFIGURATION MAXIMUM POWER DISSIPATION Typical Performance Characteristics THEORY OF OPERATION Choice of Feedback and Gain Resistors PRINTED CIRCUIT BOARD LAYOUT CONSIDERATIONS POWER SUPPLY BYPASSING DC ERRORS AND NOISE POWER CONSIDERATIONS Other Power Considerations Parallel Operation Differential Operation Creating Differential Signals Direct Single-Ended-to-Differential Conversion Twelve Channel Video Distribution Amplifier OUTLINE DIMENSIONS Ordering Guide Revision History
