Datasheet AD8044 (Analog Devices) - 2
DescriptionQuad 150 MHz Rail-to-Rail Amplifier
Pages / Page18 / 2 — AD8044* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. …
File Format / SizePDF / 322 Kb
AD8044* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. COMPARABLE PARTS. REFERENCE MATERIALS
AD8044* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017 COMPARABLE PARTS REFERENCE MATERIALS
View a parametric search of comparable parts.
Product Selection Guide
• High Speed Amplifiers Selection Table
EVALUATION KITS Tutorials
• AD8044 Evaluation Board • MT-032: Ideal Voltage Feedback (VFB) Op Amp • MT-033: Voltage Feedback Op Amp Gain and Bandwidth
DOCUMENTATION
• MT-047: Op Amp Noise
Application Notes
• MT-048: Op Amp Noise Relationships: 1/f Noise, RMS • AN-402: Replacing Output Clamping Op Amps with Input Noise, and Equivalent Noise Bandwidth Clamping Amps • MT-049: Op Amp Total Output Noise Calculations for • AN-414: Low Cost, Low Power Devices for HDSL Single-Pole System Applications • MT-050: Op Amp Total Output Noise Calculations for • AN-417: Fast Rail-to-Rail Operational Amplifiers Ease Second-Order System Design Constraints in Low Voltage High Speed Systems • MT-052: Op Amp Noise Figure: Don't Be Misled • AN-581: Biasing and Decoupling Op Amps in Single • MT-053: Op Amp Distortion: HD, THD, THD + N, IMD, Supply Applications SFDR, MTPR
Data Sheet
• MT-056: High Speed Voltage Feedback Op Amps • AD8044: Quad 150 MHz Rail-to-Rail Amplifier Data Sheet • MT-058: Effects of Feedback Capacitance on VFB and CFB
User Guides
Op Amps • UG-111: Universal Evaluation Board for Quad, High Speed • MT-059: Compensating for the Effects of Input Op Amps Offered in 14-Lead SOIC Packages Capacitance on VFB and CFB Op Amps Used in Current-to- Voltage Converters
TOOLS AND SIMULATIONS
• MT-060: Choosing Between Voltage Feedback and Current Feedback Op Amps • Analog Filter Wizard • Analog Photodiode Wizard
DESIGN RESOURCES
• Power Dissipation vs Die Temp • AD8044 Material Declaration • VRMS/dBm/dBu/dBV calculators • PCN-PDN Information • AD8044 SPICE Macro-Model • Quality And Reliability • Symbols and Footprints
DISCUSSIONS
View all AD8044 EngineerZone Discussions.
SAMPLE AND BUY
Visit the product page to see pricing options.
TECHNICAL SUPPORT
Submit a technical question or find your regional support number. Document Outline FEATURES APPLICATIONS PRODUCT DESCRIPTION CONNECTION DIAGRAM SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS MAXIMUM POWER DISSIPATION ORDERING GUIDE Typical Performance Characteristics Overdrive Recovery Circuit Description Driving Capacitance Loads APPLICATIONS RGB Buffer Active Filters Layout Considerations OUTLINE DIMENSIONS Revision History
