Datasheet AD8042 (Analog Devices) - 2
DescriptionDual 160 MHz Rail-to-Rail Amplifier
Pages / Page18 / 2 — AD8042* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. …
RevisionE
File Format / SizePDF / 363 Kb
AD8042* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. COMPARABLE PARTS. REFERENCE MATERIALS
AD8042* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017 COMPARABLE PARTS REFERENCE MATERIALS
View a parametric search of comparable parts.
Product Selection Guide
• High Speed Amplifiers Selection Table
EVALUATION KITS Tutorials
• Universal Evaluation Board for Dual High Speed • MT-032: Ideal Voltage Feedback (VFB) Op Amp Operational Amplifiers • MT-033: Voltage Feedback Op Amp Gain and Bandwidth • MT-047: Op Amp Noise
DOCUMENTATION
• MT-048: Op Amp Noise Relationships: 1/f Noise, RMS
Application Notes
Noise, and Equivalent Noise Bandwidth • AN-402: Replacing Output Clamping Op Amps with Input • MT-049: Op Amp Total Output Noise Calculations for Clamping Amps Single-Pole System • AN-414: Low Cost, Low Power Devices for HDSL • MT-050: Op Amp Total Output Noise Calculations for Applications Second-Order System • AN-417: Fast Rail-to-Rail Operational Amplifiers Ease • MT-052: Op Amp Noise Figure: Don't Be Misled Design Constraints in Low Voltage High Speed Systems • MT-053: Op Amp Distortion: HD, THD, THD + N, IMD, • AN-581: Biasing and Decoupling Op Amps in Single SFDR, MTPR Supply Applications • MT-056: High Speed Voltage Feedback Op Amps • AN-649: Using the Analog Devices Active Filter Design Tool • MT-058: Effects of Feedback Capacitance on VFB and CFB Op Amps
Data Sheet
• MT-059: Compensating for the Effects of Input • AD8042: Dual 160 MHz Rail-to-Rail Amplifier Data Sheet Capacitance on VFB and CFB Op Amps Used in Current-to-
User Guides
Voltage Converters • UG-128: Universal Evaluation Board for Dual High Speed • MT-060: Choosing Between Voltage Feedback and Op Amps in SOIC Packages Current Feedback Op Amps
TOOLS AND SIMULATIONS DESIGN RESOURCES
• Analog Filter Wizard • AD8042 Material Declaration • Analog Photodiode Wizard • PCN-PDN Information • Power Dissipation vs Die Temp • Quality And Reliability • VRMS/dBm/dBu/dBV calculators • Symbols and Footprints • AD8042 SPICE Macro-Model
DISCUSSIONS REFERENCE DESIGNS
View all AD8042 EngineerZone Discussions. • CN0143
SAMPLE AND BUY
Visit the product page to see pricing options.
TECHNICAL SUPPORT
Submit a technical question or find your regional support number. Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION CONNECTION DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS MAXIMUM POWER DISSIPATION ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS APPLICATIONS INFORMATION CIRCUIT DESCRIPTION DRIVING CAPACITIVE LOADS OVERDRIVE RECOVERY Single-Supply Composite Video Line Driver Single-Ended-to-Differential Driver Single-Supply Differential A/D Driver HDSL Line Driver LAYOUT CONSIDERATIONS OUTLINE DIMENSIONS ORDERING GUIDE
