Datasheet AD8041 (Analog Devices) - 2
Description160 MHz Rail-to-Rail Amplifier with Disable
Pages / Page18 / 2 — AD8041* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. …
RevisionB
File Format / SizePDF / 313 Kb
AD8041* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. COMPARABLE PARTS. REFERENCE MATERIALS
AD8041* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017 COMPARABLE PARTS REFERENCE MATERIALS
AD8041
View a parametric search of comparable parts.
Product Selection Guide
• High Speed Amplifiers Selection Table
EVALUATION KITS Tutorials
• Universal Evaluation Board for Single High Speed • MT-032: Ideal Voltage Feedback (VFB) Op Amp Operational Amplifiers • MT-033: Voltage Feedback Op Amp Gain and Bandwidth • MT-048: Op Amp Noise Relationships: 1/f Noise, RMS
DOCUMENTATION
Noise, and Equivalent Noise Bandwidth
Application Notes
• MT-049: Op Amp Total Output Noise Calculations for • AN-402: Replacing Output Clamping Op Amps with Input Single-Pole System Clamping Amps • MT-050: Op Amp Total Output Noise Calculations for • AN-417: Fast Rail-to-Rail Operational Amplifiers Ease Second-Order System Design Constraints in Low Voltage High Speed Systems • MT-052: Op Amp Noise Figure: Don't Be Misled • AN-581: Biasing and Decoupling Op Amps in Single • MT-053: Op Amp Distortion: HD, THD, THD + N, IMD, Supply Applications SFDR, MTPR • AN-649: Using the Analog Devices Active Filter Design • MT-056: High Speed Voltage Feedback Op Amps Tool • MT-058: Effects of Feedback Capacitance on VFB and CFB
Data Sheet
Op Amps • AD8041: 160 MHz Rail-to-Rail Amplifier with Disable Data • MT-059: Compensating for the Effects of Input Sheet Capacitance on VFB and CFB Op Amps Used in Current-to- • AD8041: Military Data Sheet Voltage Converters
User Guides
• MT-060: Choosing Between Voltage Feedback and • UG-755: 8-Lead SOIC Amplifier Evaluation Board User Current Feedback Op Amps Guide
DESIGN RESOURCES TOOLS AND SIMULATIONS
• AD8041 Material Declaration • Analog Filter Wizard • PCN-PDN Information • Analog Photodiode Wizard • Quality And Reliability • Power Dissipation vs Die Temp • Symbols and Footprints • VRMS/dBm/dBu/dBV calculators • AD8041 SPICE Macro-Model
DISCUSSIONS
View all AD8041 EngineerZone Discussions.
SAMPLE AND BUY
Visit the product page to see pricing options.
TECHNICAL SUPPORT
Submit a technical question or find your regional support number. Document Outline FEATURES APPLICATIONS PRODUCT DESCRIPTION CONNECTION DIAGRAM SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS MAXIMUM POWER DISSIPATION ORDERING GUIDE Typical Performance Characteristics Overdrive Recovery Circuit Description Output Impedance Disable Operation Single-Supply A/D Conversion APPLICATIONS RGB Buffer Single-Supply Composite Video Line Driver Sync Stripper Layout Considerations OUTLINE DIMENSIONS Revision History
