Datasheet AD8047, AD8048 (Analog Devices) - 2
Description | 250 MHz, General Purpose Voltage Feedback Op Amps |
Pages / Page | 16 / 2 — AD8047/AD8048–SPECIFICATIONS. ELECTRICAL CHARACTERISTICS (. VS =. 5 V, … |
Revision | A |
File Format / Size | PDF / 290 Kb |
AD8047/AD8048–SPECIFICATIONS. ELECTRICAL CHARACTERISTICS (. VS =. 5 V, RLOAD = 100
AD8047/AD8048–SPECIFICATIONS ELECTRICAL CHARACTERISTICS ( VS = 5 V, RLOAD = 100 , AV = 1 (AD8047), AV = 2 (AD8048), unless otherwise noted.) AD8047A AD8048A Parameter Conditions Min Typ Max Min Typ Max Unit
DYNAMIC PERFORMANCE Bandwidth (–3 dB) Small Signal VOUT ≤ 0.4 V p-p 170 250 180 260 MHz Large Signal1 VOUT = 2 V p-p 100 130 135 160 MHz Bandwidth for 0.1 dB Flatness VOUT = 300 mV p-p AD8047, RF = 0 Ω; AD8048, RF = 200 Ω 35 50 MHz Slew Rate, Average +/– VOUT = 4 V Step 475 750 740 1000 V/µs Rise/Fall Time VOUT = 0.5 V Step 1.1 1.2 ns VOUT = 4 V Step 4.3 3.2 ns Settling Time To 0.1% VOUT = 2 V Step 13 13 ns To 0.01% VOUT = 2 V Step 30 30 ns HARMONIC/NOISE PERFORMANCE Second Harmonic Distortion 2 V p-p; 20 MHz –54 –48 dBc RL = 1 kΩ –64 –60 dBc Third Harmonic Distortion 2 V p-p; 20 MHz –60 –56 dBc RL = 1 kΩ –61 –65 dBc Input Voltage Noise f = 100 kHz 5.2 3.8 nV/√Hz Input Current Noise f = 100 kHz 1.0 1.0 pA/√Hz Average Equivalent Integrated Input Noise Voltage 0.1 MHz to 10 MHz 16 11 µV rms Differential Gain Error (3.58 MHz) RL = 150 Ω, G = +2 0.02 0.01 % Differential Phase Error (3.58 MHz) RL = 150 Ω, G = +2 0.03 0.02 Degree DC PERFORMANCE2, RL = 150 Ω Input Offset Voltage3 1 3 1 3 mV TMIN to TMAX 4 4 mV Offset Voltage Drift ±5 ±5 µV/°C Input Bias Current 1 3.5 1 3.5 µA TMIN to TMAX 6.5 6.5 µA Input Offset Current 0.5 2 0.5 2 µA TMIN to TMAX 3 3 µA Common-Mode Rejection Ratio VCM = ± 2.5 V 74 80 74 80 dB Open-Loop Gain VOUT = ± 2.5 V 58 62 65 68 dB TMIN to TMAX 54 56 dB INPUT CHARACTERISTICS Input Resistance 500 500 kΩ Input Capacitance 1.5 1.5 pF Input Common-Mode Voltage Range ±3.4 ±3.4 V OUTPUT CHARACTERISTICS Output Voltage Range, RL = 150 Ω ±2.8 ±3.0 ±2.8 ±3.0 V Output Current 50 50 mA Output Resistance 0.2 0.2 Ω Short-Circuit Current 130 130 mA POWER SUPPLY Operating Range ±3.0 ±5.0 ±6.0 ±3.0 ±5.0 ±6.0 V Quiescent Current 5.8 6.6 5.9 6.6 mA TMIN to TMAX 7.5 7.5 mA Power Supply Rejection Ratio 72 78 72 78 dB NOTES 1See Absolute Maximum Ratings and Theory of Operation sections. 2Measured at AV = 50. 3Measured with respect to the inverting input. Specifications subject to change without notice. –2– REV. A Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM PRODUCT DESCRIPTION SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS METALLIZATION PHOTOS MAXIMUM POWER DISSIPATION ORDERING GUIDE Typical Performance Characteristics THEORY OF OPERATION General Feedback Resistor Choice Pulse Response Large Signal Performance Power Supply Bypassing Driving Capacitive Loads APPLICATIONS Operation as a Video Line Driver Active Filters A/D Converter Driver Layout Considerations OUTLINE DIMENSIONS Revision History
