Datasheet AD828 (Analog Devices) - 5
DescriptionDual, Low Power Video Op Amp
Pages / Page13 / 5 — AD828—Typical Performance Characteristics. 7.7. 7.2. +VCM. +85. +25. 6.7. …
RevisionC
File Format / SizePDF / 488 Kb
AD828—Typical Performance Characteristics. 7.7. 7.2. +VCM. +85. +25. 6.7. –VCM. –40. 6.2. INPUT COMMON-MODE RANGE –
AD828—Typical Performance Characteristics 7.7 7.2 +VCM +85 +25 6.7 –VCM –40 6.2 INPUT COMMON-MODE RANGE –
AD828—Typical Performance Characteristics 20 7.7 V 15 7.2 +VCM +85 C +25 C 10 6.7 –VCM –40 C 5 6.2 INPUT COMMON-MODE RANGE – QUIESCENT SUPPLY CURRENT PER AMP – mA 0 5.7 0 5 10 15 20 0 5 10 15 20 SUPPLY VOLTAGE – V SUPPLY VOLTAGE – V
TPC 1. Common-Mode Voltage Range vs. Supply TPC 4. Quiescent Supply Current per Amp vs. Supply Voltage Voltage for Various Temperatures
20 500 V 15 450 s RL = 500 10 400 RL = 150 SLEW RATE – V/ 5 350 OUTPUT VOLTAGE SWING – 0 300 0 5 10 15 20 0 5 10 15 20 SUPPLY VOLTAGE – V SUPPLY VOLTAGE – V
TPC 2. Output Voltage Swing vs. Supply Voltage TPC 5. Slew Rate vs. Supply Voltage
30 100 25 Vs = 15V 10 20 15 1 10 V 0.1 s = 5V OUTPUT VOLTAGE SWING – V p-p 5 CLOSED-LOOP OUTPUT IMPEDANCE – 0 0.01 10 100 1k 10k 1k 10k 100k 1M 10M 100M LOAD RESISTANCE – FREQUENCY – Hz
TPC 3. Output Voltage Swing vs. Load Resistance TPC 6. Closed-Loop Output Impedance vs. Frequency –4– REV. C
