Datasheet AD826 (Analog Devices) - 2
DescriptionLow Cost, High Speed, Low Power Dual Operational Amplifier
Pages / Page16 / 2 — AD826* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. …
RevisionC
File Format / SizePDF / 811 Kb
AD826* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. COMPARABLE PARTS. REFERENCE MATERIALS
AD826* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017 COMPARABLE PARTS REFERENCE MATERIALS
View a parametric search of comparable parts.
Product Selection Guide
• High Speed Amplifiers Selection Table
EVALUATION KITS Tutorials
• Universal Evaluation Board for Dual High Speed • MT-032: Ideal Voltage Feedback (VFB) Op Amp Operational Amplifiers • MT-033: Voltage Feedback Op Amp Gain and Bandwidth • MT-047: Op Amp Noise
DOCUMENTATION
• MT-048: Op Amp Noise Relationships: 1/f Noise, RMS
Application Notes
Noise, and Equivalent Noise Bandwidth • AN-356: User's Guide to Applying and Measuring • MT-049: Op Amp Total Output Noise Calculations for Operational Amplifier Specifications Single-Pole System • AN-402: Replacing Output Clamping Op Amps with Input • MT-050: Op Amp Total Output Noise Calculations for Clamping Amps Second-Order System • AN-417: Fast Rail-to-Rail Operational Amplifiers Ease • MT-052: Op Amp Noise Figure: Don't Be Misled Design Constraints in Low Voltage High Speed Systems • MT-053: Op Amp Distortion: HD, THD, THD + N, IMD, • AN-581: Biasing and Decoupling Op Amps in Single SFDR, MTPR Supply Applications • MT-056: High Speed Voltage Feedback Op Amps • AN-649: Using the Analog Devices Active Filter Design Tool • MT-058: Effects of Feedback Capacitance on VFB and CFB Op Amps
Data Sheet
• MT-060: Choosing Between Voltage Feedback and • AD826: High Speed, Low Power Dual Operational Current Feedback Op Amps Amplifier Data Sheet
User Guides DESIGN RESOURCES
• UG-128: Universal Evaluation Board for Dual High Speed • AD826 Material Declaration Op Amps in SOIC Packages • PCN-PDN Information
TOOLS AND SIMULATIONS
• Quality And Reliability • Analog Filter Wizard • Symbols and Footprints • Analog Photodiode Wizard
DISCUSSIONS
• Power Dissipation vs Die Temp View all AD826 EngineerZone Discussions. • VRMS/dBm/dBu/dBV calculators • AD826 SPICE Macro-Model
SAMPLE AND BUY
Visit the product page to see pricing options.
TECHNICAL SUPPORT
Submit a technical question or find your regional support number.
DOCUMENT FEEDBACK
Submit feedback for this data sheet.
