Datasheet SSM2135 (Analog Devices)
Description | Dual Single-Supply Audio Operational Amplifier |
Pages / Page | 17 / 1 — Dual Single-Supply. Audio Operational Amplifier. SSM2135. FEATURES. PIN … |
Revision | G |
File Format / Size | PDF / 328 Kb |
Dual Single-Supply. Audio Operational Amplifier. SSM2135. FEATURES. PIN CONNECTIONS. Excellent sonic characteristics. OUT A 1
Dual Single-Supply Audio Operational Amplifier SSM2135 FEATURES PIN CONNECTIONS Excellent sonic characteristics OUT A 1 8 V+ High output drive capability –IN A 2 SSM2135 7 OUT B 5.2 nV/√Hz equivalent input noise @ 1 kHz +IN A 3 TOP VIEW 6 –IN B (Not to Scale)
02 0
0.003% THD + N (V
9-
OUT = 1 V p-p @ 1 kHz) V–/GND 4 5 +IN B
34 00
3.5 MHz gain bandwidth
Figure 1. 8-Lead Narrow Body SOIC (R Suffix)
Unity-gain stable Low cost APPLICATIONS Multimedia audio systems Microphone preamplifiers Headphone drivers Differential line receivers Balanced line drivers Audio ADC input buffers Audio DAC l-V converters and filters Pseudoground generators GENERAL DESCRIPTION
The SSM2135 dual audio operational amplifier permits excel- and portable digital audio units, the SSM2135 can perform lent performance in portable or low power audio systems, with preamplification, headphone and speaker driving, and balanced an operating supply range of 4 V to 36 V or ±2 V to ±18 V. line driving and receiving. Additionally, the device is ideal for The unity-gain stable device has very low voltage noise of input signal conditioning in single-supply, Σ-Δ, analog-to- 5.2 nV/√Hz, and total harmonic distortion plus noise below digital converter subsystems such as the AD1877. The SSM2135 0.01% over normal signal levels and loads. Such characteristics makes an ideal single-supply stereo output amplifier for audio are enhanced by wide output swing and load drive capability. digital-to-analog converters (DACs) because of its low noise A unique output stage permits output swing approaching the and distortion. rail under moderate load conditions. Under severe loading, The SSM2135 is available in an 8-lead plastic SOIC package the SSM2135 still maintains a wide output swing with ultralow and is guaranteed for operation over the extended industrial distortion. Particularly well suited for computer audio systems temperature range of −40°C to +85°C.
FUNCTIONAL BLOCK DIAGRAM V+ +INx OUTx 9V 9V –INx
001 9-
V–/GND
034 0 Figure 2.
Rev. G Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. rights of third parties that may result from its use. Specifications subject to change without notice. No license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 www.analog.com Trademarks and registered trademarks are the property of their respective owners. Fax: 781.461.3113 ©2003–2011 Analog Devices, Inc. All rights reserved.
Document Outline FEATURES APPLICATIONS PIN CONNECTIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS APPLICATIONS INFORMATION APPLICATION CIRCUITS Low Noise Stereo Headphone Driver Amplifier Low Noise Microphone Preamplifier Single Supply Differential Line Driver Single-Supply Differential Line Receiver Pseudoreference Voltage Generator Digital Volume Control Circuit Logarithmic Volume Control Circuit OUTLINE DIMENSIONS ORDERING GUIDE
