Datasheet OP275 (Analog Devices) - 2
DescriptionBipolar/JFET, Audio Dual Op Amp
Pages / Page13 / 2 — OP275* PRODUCT PAGE QUICK LINKS Last Content Update: 06/09/2017. …
RevisionC
File Format / SizePDF / 306 Kb
OP275* PRODUCT PAGE QUICK LINKS Last Content Update: 06/09/2017. COMPARABLE PARTS. DESIGN RESOURCES. EVALUATION KITS
OP275* PRODUCT PAGE QUICK LINKS Last Content Update: 06/09/2017 COMPARABLE PARTS DESIGN RESOURCES EVALUATION KITS
View a parametric search of comparable parts. • OP275 Material Declaration • PCN-PDN Information
EVALUATION KITS
• Quality And Reliability • EVAL-OPAMP-2 Evaluation Board • Symbols and Footprints
DOCUMENTATION DISCUSSIONS Application Notes
View all OP275 EngineerZone Discussions. • AN-211: The Alexander Current-Feedback Audio Power Amplifier
SAMPLE AND BUY
• AN-356: User's Guide to Applying and Measuring Visit the product page to see pricing options. Operational Amplifier Specifications • AN-649: Using the Analog Devices Active Filter Design
TECHNICAL SUPPORT
Tool Submit a technical question or find your regional support
Data Sheet
number. • OP275: Dual Bipolar/JFET, Audio Operational Amplifier Data Sheet
DOCUMENT FEEDBACK TOOLS AND SIMULATIONS
Submit feedback for this data sheet. • Analog Filter Wizard • Analog Photodiode Wizard • OP275 SPICE Macro Models
Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION PIN CONNECTIONS SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ORDERING GUIDE Typical Performance Characteristics APPLICATIONS Circuit Protection Total Harmonic Distortion Noise Noise Testing Input Overcurrent Protection Output Voltage Phase Reversal Overload or Overdrive Recovery Measuring Settling Time Driving Capacitive Loads High Speed, Low Noise Differential Line Driver A 3-Pole, 40 kHz Low-Pass Filter OP275 SPICE Model OUTLINE DIMENSIONS Revision History
