Datasheet OP275 (Analog Devices) - 7
Description | Bipolar/JFET, Audio Dual Op Amp |
Pages / Page | 13 / 7 — OP275. 200. BASED ON 920 OP AMPS. VS =. 15V. TA = 25. 160. +0.1%. +0.01%. … |
Revision | C |
File Format / Size | PDF / 306 Kb |
OP275. 200. BASED ON 920 OP AMPS. VS =. 15V. TA = 25. 160. +0.1%. +0.01%. s 40. 120. UNITS. –SR. STEP SIZE –. –0.1%. –0.01%. SLEW RATE –. +SR. –10
OP275 OP275 200 10 50 BASED ON 920 OP AMPS VS =
15V 8 TA = 25
C TA = 25
C 45 VS =
15V 160 6 +0.1% +0.01% 4 V s 40 120 2 /
V 0 35 UNITS –SR 80 –2 STEP SIZE – 30 –4 –0.1% –0.01% 40 SLEW RATE – +SR –6 25 –8 0 –10 20 –500–400–300–200–100 0 100 200 300 400 500 0 100 200 300 400 500 600 700 800 900 0 100 200 300 400 500 INPUT OFFSET VOLTAGE –
V SETTLING TIME – ns CAPACITIVE LOAD – pF
TPC 19. Input Offset (VOS) TPC 20. Step Size vs. Settling TPC 21. Slew Rate vs. Capacitive Distribution Time Load
40 50 35 VS =
15V V R 45 S =
15V L = 2k
RL = 2k
–SR 100 30 s TA = 25
C 90
s 40 25
20 35 15 SLEW RATE – V/ 30 +SR 10 10 SLEW RATE – V/ 0% 25 5 5V 200ns 0 20 0 0.2 0.4 0.6 0.8 1.0 –50 –25 0 25 50 75 100 TEMPERATURE –
C DIFFERENTIAL INPUT VOLTAGE – V
TPC 22. Slew Rate vs. Differential TPC 23. Slew Rate vs. Temperature TPC 24. Negative Slew Rate Input Voltage RL = 2 k , VS = ±15 V, AV = +1
CH A: 80.0
V FS 10.0
V/DIV MKR: 6.23 nV/ Hz 100 100 90 90 10 10 0% 0% 5V 200ns 50mV 100ns 0 Hz 2.5 kHz MKR: 1 000 Hz BW: 15.0 MHz
TPC 25. Positive Slew Rate TPC 26. Small Signal Response TPC 27. Voltage Noise Density RL = 2 k , VS = ±15 V, AV = +1 RL = 2 k , VS = ±5 V, AV = +1 vs. Frequency VS = ±15 V –6– REV. C REV. C –7– Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION PIN CONNECTIONS SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ORDERING GUIDE Typical Performance Characteristics APPLICATIONS Circuit Protection Total Harmonic Distortion Noise Noise Testing Input Overcurrent Protection Output Voltage Phase Reversal Overload or Overdrive Recovery Measuring Settling Time Driving Capacitive Loads High Speed, Low Noise Differential Line Driver A 3-Pole, 40 kHz Low-Pass Filter OP275 SPICE Model OUTLINE DIMENSIONS Revision History
