Datasheet OP282, OP482 (Analog Devices) - 8
Description | Dual/Quad, Low Power, High Speed JFET Operational Amplifiers |
Pages / Page | 16 / 8 — OP282/OP482. Data Sheet. 400. S = ±15V. VCL = 1. VS = ±15V. 360. 300 × … |
Revision | I |
File Format / Size | PDF / 318 Kb |
OP282/OP482. Data Sheet. 400. S = ±15V. VCL = 1. VS = ±15V. 360. 300 × OP282. NEGATIVE EDGE. (600 OP AMPS). L = 2kΩ. VIN = 100mV p-p. 320. 280
OP282/OP482 Data Sheet 400 70 V A S = ±15V VCL = 1 VS = ±15V 360 300 × OP282 NEGATIVE EDGE R (600 OP AMPS) L = 2kΩ 60 VIN = 100mV p-p 320 280 50 ) AVCL = 1 240 (% T 40 POSITIVE EDGE S O T 200 O UNI SH 30 160 VER O 120 20 80 10 40
023 026
0
00301-
0
00301-
0 4 8 12 16 20 24 28 32 36 0 100 200 300 400 500 TCVOS (µV/°C) LOAD CAPACITANCE (pF)
Figure 24. OP282 TCVOS Distribution, SOIC_N Package Figure 27. OP482 Small-Signal Overshoot vs. Load Capacitance
80 0 60 VS = ±15V VS = ±15V TA = 25°C TA = 25°C 50 60 45 AVCL = 100 B) 40 d B) d N ( 30 N ( 40 90 AI rees) AI G A P VCL = 10 G P Deg 20 ( O E O -LOO 20 135 D -L HAS E 10 P PEN A LOS VCL = 1 O C 0 0 180 –10
027
–20
00301-
1k 10k 100k 1M 10M 100M
024
1k 10k 100k 1M 10M 100M FREQUENCY (Hz)
00301-
FREQUENCY (Hz)
Figure 25. OP482 Open-Loop Gain and Phase vs. Frequency Figure 28. OP482 Closed-Loop Gain vs. Frequency
35 25 VS = ±15V –SR R 30 L = 10kΩ 20 ) VS = ±15V 25 R /mV L = 10kΩ V s) C µ L = 50pF N ( 15 AI 20 E (V/ G T P A O R O 15 -L 10 EW +SR SL PEN 10 O 5 5
025 028 00301-
0
00301-
0 –75 –50 –25 0 25 50 75 100 125 –75 –50 –25 0 25 50 75 100 125 TEMPERATURE (°C) TEMPERATURE (°C)
Figure 26. OP482 Open-Loop Gain vs. Temperature Figure 29. OP482 Slew Rate vs. Temperature Rev. I | Page 8 of 16 Document Outline Features Applications General Description Pin Connections Table of Contents Revision History Specifications Electrical Characteristics Absolute Maximum Ratings Thermal Resistance ESD Caution Typical Performance Characteristics Applications Information High-Side Signal Conditioning Phase Inversion Active Filters Programmable State Variable Filter Outline Dimensions Ordering Guide
