Datasheet OP297 (Analog Devices) - 9 Manufacturer Analog Devices Description Low Bias Current Precision (Dual) Operational Amplifier Pages / Page 17 / 9 — OP297. 100. S = ±15V. A = 25°C. L = 30pF. L = 1MΩ. GAIN. ) B 60. rees). … Revision G File Format / Size PDF / 300 Kb Document Language English
OP297. 100. S = ±15V. A = 25°C. L = 30pF. L = 1MΩ. GAIN. ) B 60. rees). PHASE. NCE. A = –55°C. OOP. 135. 0.1. HAS. 180. UT O. 0.01. –20. 225. TA = +125°C. –40. 270
Model Line for this Datasheet Text Version of Document OP297 100 1k V T S = ±15V A = 25°C C V 80 L = 30pF S = ±15V R 100 L = 1MΩ GAIN ) ) B 60 Ω d ( ( rees) 10 IN PHASE eg NCE D 40 90 GA ( DA T E T IF P 1 A = –55°C OOP H M 20 135 I -L S N E UT E P 0.1 HAS OP 0 180 P UT O 0.01 –20 225 TA = +125°C –40 270 0.001 100 1k 10k 100k 1M 10M 23 25 010 100 1k 10k 100k 1M 0 0- 0-FREQUENCY (Hz) 30FREQUENCY (Hz) 30 00 00 Figure 23. Open-Loop Gain, Phase vs. Frequency Figure 25. Open-Loop Output Impedance vs. Frequency70 T A = 25°C V 60 S = ±15V AVCL = +1 VOUT = 100mV p-p –EDGE 50 ) % ( T O 40 O +EDGE SH 30 VER O 20 10 0 2410 100 1k 10k -0 00LOAD CAPACITANCE (pF) 03 0 Figure 24. Small Signal Overshoot vs. Load Capacitance Rev. G | Page 8 of 16 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION PIN CONFIGURATION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS APPLICATIONS INFORMATION AC PERFORMANCE GUARDING AND SHIELDING OPEN-LOOP GAIN LINEARITY APPLICATION CIRCUITS PRECISION ABSOLUTE VALUE AMPLIFIER PRECISION CURRENT PUMP PRECISION POSITIVE PEAK DETECTOR SIMPLE BRIDGE CONDITIONING AMPLIFIER NONLINEAR CIRCUITS OUTLINE DIMENSIONS ORDERING GUIDE
