Datasheet OP249 (Analog Devices) - 9
DescriptionPrecision JFET High Speed Dual Op Amp
Pages / Page19 / 9 — OP249. Data Sheet. 0.01. TA = 25°C. VS = ±15V. VO = 10V p-p RL = 10kΩ AV …
RevisionI
File Format / SizePDF / 445 Kb
OP249. Data Sheet. 0.01. TA = 25°C. VS = ±15V. VO = 10V p-p RL = 10kΩ AV = 1. ) s. NEGATIVE. E (V/ T A. POSITIVE. EW SL. 0.001. 100. 200. 300. 400. 500
OP249 Data Sheet 0.01 TA = 25°C VS = ±15V VO = 10V p-p RL = 10kΩ AV = 1 ) s NEGATIVE E (V/ T A POSITIVE EW SL 0.001 100 200 300 400 500
OP249 Data Sheet 35 0.01 TA = 25°C TA = 25°C VS = ±15V VS = ±15V 30 VO = 10V p-p RL = 10kΩ AV = 1 ) s 25 NEGATIVE µ E (V/ T A 20 POSITIVE R EW SL 15 10
012 015
5
00296-
0.001
00296-
0 100 200 300 400 500 20 100 1k 10k 20k CAPACITIVE LOAD (pF)
Figure 12. Slew Rate vs. Capacitive Load Figure 15. Distortion vs. Frequency
10 0.01 TA = 25°C TA = 25°C 8 VS = ±15V VS = ±15V AVCL = 1 VO = 10V p-p 6 RL = 2kΩ 0.1% AV = 1 4 E (V) 0.01% Z 2 EP SI 0 ST T –2 PU 0.01% T U –4 O 0.1% –6 –8
013 016
–10
00296-
0.001
00296-
0 200 400 600 800 1000 20 100 1k 10k 20k SETTLING TIME (ns)
Figure 13. Step Size vs. Settling Time Figure 16. Distortion vs. Frequency
100 TA = 25°C 0.01 VS = ±15V T ) A = 25°C V Hz S = ±15V 80 VO = 10V p-p V/ RL = 600Ω A Y (n V = 1 T SI 60 EN ISE D O 40 E N G A T L 20 VO
014 017
0
00296-
0 100 1k 10k 0.001
00296-
FREQUENCY (Hz) 20 100 1k 10k 20k
Figure 14. Voltage Noise Density vs. Frequency Figure 17. Distortion vs. Frequency Rev. I | Page 8 of 18 Document Outline Features Applications Pin Configurations General Description Table of Contents Revision History Specifications Electrical Characteristics Absolute Maximum Ratings ESD Caution Typical Performance Characteristics Applications Information Open-Loop Gain Linearity Offset Voltage Adjustment Settling Time DAC Output Amplifier Discussion on Driving ADCs Outline Dimensions Ordering Guide
