Datasheet AD845 (Analog Devices) - 2
DescriptionPrecision, 16 MHz CBFET Op Amp
Pages / Page13 / 2 — AD845* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. …
RevisionE
File Format / SizePDF / 223 Kb
AD845* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. COMPARABLE PARTS. REFERENCE MATERIALS. Tutorials
AD845* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017 COMPARABLE PARTS REFERENCE MATERIALS Tutorials
AD845
View a parametric search of comparable parts.
Tutorials
• MT-032: Ideal Voltage Feedback (VFB) Op Amp
DOCUMENTATION
• MT-033: Voltage Feedback Op Amp Gain and Bandwidth
Application Notes
• MT-047: Op Amp Noise • AN-402: Replacing Output Clamping Op Amps with Input • MT-048: Op Amp Noise Relationships: 1/f Noise, RMS Clamping Amps Noise, and Equivalent Noise Bandwidth • AN-417: Fast Rail-to-Rail Operational Amplifiers Ease • MT-049: Op Amp Total Output Noise Calculations for Design Constraints in Low Voltage High Speed Systems Single-Pole System • AN-581: Biasing and Decoupling Op Amps in Single • MT-050: Op Amp Total Output Noise Calculations for Supply Applications Second-Order System
Data Sheet
• MT-052: Op Amp Noise Figure: Don't Be Misled • AD845: Military Data Sheet • MT-053: Op Amp Distortion: HD, THD, THD + N, IMD, • AD845: Precision, 16 MHz CBFET Op Amp Data Sheet SFDR, MTPR • MT-056: High Speed Voltage Feedback Op Amps
TOOLS AND SIMULATIONS
• MT-058: Effects of Feedback Capacitance on VFB and CFB • Analog Filter Wizard Op Amps • Analog Photodiode Wizard • MT-059: Compensating for the Effects of Input Capacitance on VFB and CFB Op Amps Used in Current-to- • Power Dissipation vs Die Temp Voltage Converters • VRMS/dBm/dBu/dBV calculators • MT-060: Choosing Between Voltage Feedback and • AD845 SPICE Macro-Model Current Feedback Op Amps
REFERENCE DESIGNS DESIGN RESOURCES
• CN0042 • AD845 Material Declaration • PCN-PDN Information • Quality And Reliability • Symbols and Footprints
DISCUSSIONS
View all AD845 EngineerZone Discussions.
SAMPLE AND BUY
Visit the product page to see pricing options.
TECHNICAL SUPPORT
Submit a technical question or find your regional support number.
DOCUMENT FEEDBACK
Submit feedback for this data sheet.
This page is dynamically generated by Analog Devices, Inc., and inserted into this data sheet. A dynamic change to the content on this page will not trigger a change to either the revision number or the content of the product data sheet. This dynamic page may be frequently modified.
Document Outline FEATURES AC PERFORMANCE: DC PERFORMANCE: CONNECTION DIAGRAMS GENERAL DESCRIPTION PRODUCT HIGHLIGHTS SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS METALIZATION PHOTOGRAPH ORDERING GUIDE Typical Performance Characteristics MEASURING AD845 SETTLING TIME A HIGH SPEED INSTRUMENTATION AMP DRIVING THE ANALOG INPUT OF AN A/D CONVERTER OUTLINE DIMENSIONS Revision History
