Datasheet OP97 (Analog Devices) - 8
Description | Low Power, High Precision Operational Amplifier |
Pages / Page | 17 / 8 — OP97. 1000. 450. BALANCED OR UNBALANCED. NO LOAD. VS = ±15V VCM = 0V. … |
Revision | G |
File Format / Size | PDF / 567 Kb |
OP97. 1000. 450. BALANCED OR UNBALANCED. NO LOAD. VS = ±15V VCM = 0V. 425. (µV) E G A. T 100. (µ 400 NT. A = +125°C. T E. –55°C ≤ T. A ≤ +125°C
OP97 1000 450 BALANCED OR UNBALANCED NO LOAD VS = ±15V VCM = 0V 425 (µV) E G A A) T 100 L (µ 400 NT T VO E A = +125°C T E –55°C ≤ T S A ≤ +125°C 375 T F A = +25°C F CURR Y L TA = 25°C P 10 IVE O 350 T UP TA = –55°C C S E F F E 325 1
08
300
11
1k 3k 10k 30k 100k 300k 1M 3M 10M
0 0 9-
0 5 10 15 20
9-
SOURCE RESISTANCE (Ω)
29
SUPPLY VOLTAGE (±V)
29 00 00 Figure 8. Effective Offset Voltage vs. Source Resistance Figure 11. Supply Current vs. Supply Voltage
100 140 ) BALANCED OR UNBALANCED T °C A = 25°C VS = ±15V VS = ±15V 120 (µV/ VCM = 0V VCM = ±10V T B) IF (d R N 100 D IO E 10 G CT A T JE L 80 RE VO T DE E O 60 S F -M F 1 N O M 40 IVE O M T C CO E 20 F F E 0.1
09
0
12
1k 10k 100k 1M 10M 100M
0
1 10 100 1k 10k 100k 1M
0 9- 9-
29
FREQUENCY (Hz)
29 00 00 Figure 9. Effective TCVOS vs. Source Resistance Figure 12. Common-Mode Rejection vs. Frequency
20 140 T T A = 25°C A = –55°C 15 VS = ±15V 120 ΔVS = 10V p-p A) B) TA = +25°C d 10 (m N ( T N IO T T 100 A = +125°C 5 C JE URRE –PSR C VS = ±15V T 0 RE 80 Y OUTPUT SHORTED TO GROUND L P RCUI P –5 U +PSR -CI TA = +125°C 60 T R S R E O –10 T H A = +25°C W S O P 40 T –15 A = –55°C –20
10
20
13
0 1 2 3
0 9-
0.1 1 10 100 1k 10k 100k 1M
0 9-
TIME FROM OUTPUT SHORT (Minutes)
29
FREQUENCY (Hz)
29 00 00 Figure 10. Short-Circuit Current vs. Time, Temperature Figure 13. Power Supply Rejection vs. Frequency Rev. G | Page 7 of 16 Document Outline FEATURES PIN CONNECTIONS GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS APPLICATION INFORMATION AC PERFORMANCE GUARDING AND SHIELDING OUTLINE DIMENSIONS ORDERING GUIDE
