Datasheet OP200 (Analog Devices) - 6
DescriptionDual Low Offset, Low Power Operational Amplifier
Pages / Page17 / 6 — Data Sheet. OP200. Table 3. OP200A/OP200E. OP200G. Parameter. Symbol. …
RevisionG
File Format / SizePDF / 414 Kb
Data Sheet. OP200. Table 3. OP200A/OP200E. OP200G. Parameter. Symbol. Conditions. Min. Typ. Max. Unit. Table 4. OP200E. Symbol Conditions
Data Sheet OP200 Table 3 OP200A/OP200E OP200G Parameter Symbol Conditions Min Typ Max Unit Table 4 OP200E Symbol Conditions
Data Sheet OP200
VS = ±15 V, TA = 25°C, unless otherwise noted.
Table 3. OP200A/OP200E OP200G Parameter Symbol Conditions Min Typ Max Min Typ Max Unit
INPUT CHARACTERISTICS Input Voltage Range1 IVR ±12 ±13 ±12 ±13 V Common-Mode Rejection Ratio CMRR VCM = ±12 V 120 135 110 130 dB Channel Separation2 CS VO = 20 V p-p, fO = 10 Hz 123 145 123 145 dB Input Capacitance CIN 3.2 3.2 pF Capacitive Load Stability AV = 1, no oscillations 10 10 nF POWER SUPPLY Power Supply Rejection Ratio PSRR VS = ±3 V to ±18 V 0.4 1.8 0.6 5.6 μV/V Supply Current Per Amplifier ISY No load 570 725 570 725 μA OUTPUT CHARACTERISTICS Output Voltage Swing VO RL= 10 kΩ ±12 ±12.6 ±12 ±12.6 V RL = 2 kΩ ±11 ±12.2 ±11 ±12.2 V DYNAMIC PERFORMANCE Slew Rate SR 0.1 0.15 0.1 0.15 V/μs Gain Bandwidth Product GBP AV = 1 500 500 kHz 1 Guaranteed by CMRR test. 2 Guaranteed but not 100% tested. VS = ±15 V, −40°C ≤ TA ≤ +85°C, unless otherwise noted.
Table 4. OP200E OP200G Parameter Symbol Conditions Min Typ Max Min Typ Max Unit
INPUT CHARACTERISTICS Input Offset Voltage VOS 35 100 110 300 μV Average Input Offset Voltage Drift TCVOS 0.2 0.5 0.6 2.0 μV/°C Input Offset Current IOS VCM = 0 V 0.08 2.5 0.1 6.0 nA Input Bias Current IB VCM = 0 V 0 3 5.0 0.5 10.0 nA Large-Signal Voltage Gain AVO VO = ±10 V RL= 10 kΩ 3000 10,000 2000 5000 V/mV RL = 2 kΩ 1500 3200 1000 2500 V/mV Input Voltage Range1 IVR ±12 ±12.5 ±12 ±12.5 V Common-Mode Rejection Ratio CMRR VCM = ±12 V 115 130 105 130 dB Capacitive Load Stability AV = 1, no oscillations 10 10 nF POWER SUPPLY Power Supply Rejection Ratio PSRR VS = ±3 V to ±18 V 0.15 3.2 0.3 10.0 μV/V Supply Current Per Amplifier ISY No load 600 775 600 775 μA OUTPUT CHARACTERISTICS Output Voltage Swing VO RL = 10 kΩ ±12 ±12.4 ±12 ±12.4 V RL = 2 kΩ ±11 ±12 ±11 ±12.2 V 1 Guaranteed by CMRR test. Rev. G | Page 5 of 16 Document Outline FEATURES PIN CONNECTIONS GENERAL DESCRIPTION REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS APPLICATIONS INFORMATION DUAL LOW POWER INSTRUMENTATION AMPLIFIER PRECISION ABSOLUTE VALUE AMPLIFIER PRECISION CURRENT PUMP DUAL 12-BIT VOLTAGE OUTPUT DAC DUAL PRECISION VOLTAGE REFERENCE PROGRAMMABLE HIGH RESOLUTION WINDOW COMPARATOR OUTLINE DIMENSIONS ORDERING GUIDE
