Datasheet OP200 (Analog Devices) - 9
DescriptionDual Low Offset, Low Power Operational Amplifier
Pages / Page17 / 9 — OP200. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. 300. A = 25°C. S …
RevisionG
File Format / SizePDF / 414 Kb
OP200. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. 300. A = 25°C. S = ±15V. ) V. VS = ±15V. 250. p (. AG T. 200. L O. V T E. CUR. 150. N O. 100. E G
OP200 Data Sheet TYPICAL PERFORMANCE CHARACTERISTICS 300 A = 25°C S = ±15V ) V VS = ±15V 250 p ( AG T 200 L O V T E CUR 150 N O 100 E G
OP200 Data Sheet TYPICAL PERFORMANCE CHARACTERISTICS 300 T V A = 25°C S = ±15V ) V VS = ±15V 250 µ 2 ( A) E p ( AG T NT 200 L O RE V T E CUR S 150 T F E F S 1 F N O F I O 100 E G UT INP CHAN 50
6 09 00 0 2- 2- 32 32
0
00
0
00
0 1.0 2.0 3.0 4.0 5.0 –75 –50 –25 0 25 50 75 100 125 TIME (Minutes) TEMPERATURE (°C)
Figure 6. Warm-Up Drift Figure 9. Input Offset Current vs. Temperature
60 1.0 VS = ±15V TA = 25°C V 50 S = ±15V ) V 0.8 µ A) E ( G (n 40 A T NT L E 0.6 VO 30 ET CURR S F AS F 0.4 BI O 20 T UT PU INP IN 0.2 10
07 10 0 0 2- 2- 32 32
0
00
0
00
–75 –50 –25 0 25 50 75 100 125 –15 –10 –5.0 0 5.0 10 15 TEMPERATURE (°C) COMON-MODE VOLTAGE (V)
Figure 7. Input Offset Voltage vs. Temperature Figure 10. Input Bias Current vs. Common-Mode Voltage
3 140 TA = 25°C VS = ±15V VS = ±15V 120 2 B) ) d A n N ( 100 ( 1 IO T NT C JE 80 0 RE CURRE DE AS 60 O BI M –1 N- UT O 40 M INP M O –2 C 20
08 11 0 0 2- 2- 32 32
–3
00
0
00
–75 –50 –25 0 25 50 75 100 125 1 10 100 1k 10k 100k TEMPERATURE (°C) FREQUENCY (Hz)
Figure 8. Input Bias Current vs. Temperature Figure 11. Common-Mode Rejection vs. Frequency Rev. G | Page 8 of 16 Document Outline FEATURES PIN CONNECTIONS GENERAL DESCRIPTION REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS APPLICATIONS INFORMATION DUAL LOW POWER INSTRUMENTATION AMPLIFIER PRECISION ABSOLUTE VALUE AMPLIFIER PRECISION CURRENT PUMP DUAL 12-BIT VOLTAGE OUTPUT DAC DUAL PRECISION VOLTAGE REFERENCE PROGRAMMABLE HIGH RESOLUTION WINDOW COMPARATOR OUTLINE DIMENSIONS ORDERING GUIDE
