Datasheet OP471 (Analog Devices) - 7
Description | High Speed, Low Noise Quad Operational Amplifier |
Pages / Page | 17 / 7 — OP471. 360. TA = 25. V 24. S =. 15V. VS =. THD = 1%. 300. POSITIVE. … |
Revision | A |
File Format / Size | PDF / 337 Kb |
OP471. 360. TA = 25. V 24. S =. 15V. VS =. THD = 1%. 300. POSITIVE. SWING. 240. ANCE –. NEGATIVE. 180. O-PEAK AMPLITUDE –. 120. MAXIMUM OUTPUT –
OP471 28 20 360 TA = 25 C TA = 25 C TA = 25 C V 18 V V 24 S = 15V S = 15V VS = 15V THD = 1% 300 16 V 20 POSITIVE 14 SWING 240 12 16 ANCE – 10 NEGATIVE 180 12 SWING 8 O-PEAK AMPLITUDE – 120 8 6 MAXIMUM OUTPUT – OUTPUT IMPED AV = 100 4 PEAK-T 60 4 2 AV = 1 0 0 0 1k 10k 100k 1M 10M 100 1k 10k 100 1k 10k 100k 1M 10M 100M FREQUENCY – Hz LOAD RESISTANCE – FREQUENCY – Hz
TPC 19. Maximum Output Swing TPC 20. Maximum Output Voltage TPC 21. Closed-Loop Output vs. Frequency vs. Load Resistance Impedance vs. Frequency
9.0 170 1 TA = 25 C 160 TA = 25 C VS = 15V V 8.5 150 S = 15V VO = 20V p-p TO 100kHz VO = 10V p-p 140 RL = 2k s –SR TION – % 8.0 130 0.1 V/ OR +SR TION – dB 120 TE – 7.5 ARA 110 100 7.0 90 0.01 SLEW RA 80 A L HARMONIC DIST V = 10 6.5 CHANNEL SEP 70 TA 60 TO AV = 1 6.0 50 0.001 –75 –50 –25 0 25 50 75 100 125 10 100 1k 10k 100k 1M 10M 10 100 1k 10k TEMPERATURE – C FREQUENCY – Hz FREQUENCY – Hz
TPC 22. Slew Rate vs. Temperature TPC 23. Channel Separation vs. TPC 24. Total Harmonic Distortion Frequency vs. Frequency
TA = 25 C TA = 25 C VS = 15V VS = 15V 100 A 100 V = 1 AV = 1 90 90 10 10 0% 0% 5V 5µs 50mV 0.2µs
TPC 25. Large-Signal Transient TPC 26. Small-Signal Transient Response Response –6– REV. A
