Datasheet OP470 (Analog Devices)
Description | Low Noise Quad Op Amp |
Pages / Page | 17 / 1 — Very Low Noise Quad. Operational Amplifier. OP470. FEATURES. PIN … |
Revision | B |
File Format / Size | PDF / 888 Kb |
Very Low Noise Quad. Operational Amplifier. OP470. FEATURES. PIN CONNECTIONS. Very Low-Noise, 5 nV/
a
Very Low Noise Quad Operational Amplifier OP470 FEATURES PIN CONNECTIONS Very Low-Noise, 5 nV/
Hz @ 1 kHz Max Excellent Input Offset Voltage, 0.4 mV Max 14-Lead Hermetic DIP 16-Lead SOIC Package Low Offset Voltage Drift, 2 V/ C Max (Y-Suffix) (S-Suffix) Very High Gain, 1000 V/mV Min 14-Lead Plastic DIP Outstanding CMR, 110 dB Min (P-Suffix) OUT A 1 16 OUT D Slew Rate, 2 V/ s Typ –IN A 2 15 –IN D Gain-Bandwidth Product, 6 MHz Typ +IN A 3 14 +IN D Industry Standard Quad Pinouts OUT A 1 14 OUT D Available in Die Form –IN A 2 13 –IN D V+ 4 13 OP470 V– +IN A 3 12 +IN D +IN B 5 12 +IN C GENERAL DESCRIPTION V+ 4 OP470 11 V– –IN B 6 11 –IN C
The OP470 is a high-performance monolithic quad operational
+IN B 5 10 +IN C OUT B 7 10 OUT C
amplifier with exceptionally low voltage noise, 5 nV/÷Hz at
–IN B 6 9 –IN C NC 8 9 NC
1 kHz max, offering comparable performance to ADI’s industry
OUT B 7 8 OUT C NC = NO CONNECT
standard OP27. The OP470 features an input offset voltage below 0.4 mV, excellent for a quad op amp, and an offset drift under 2 mV/∞C, The OP470 offers excellent amplifier matching which is impor- guaranteed over the full military temperature range. Open loop tant for applications such as multiple gain blocks, low noise gain of the OP470 is over 1,000,000 into a 10 kW load ensuring instrumentation amplifiers, quad buffers, and low noise active excellent gain accuracy and linearity, even in high gain applica- filters. tions. Input bias current is under 25 nA, which reduces errors due to signal source resistance. The OP470’s CMR of over 110 The OP470 conforms to the industry standard 14-lead DIP dB and PSRR of less than 1.8 mV/V significantly reduce errors pinout. It is pin compatible with the LM148/149, HA4741, due to ground noise and power supply fluctuations. Power HA5104, and RM4156 quad op amps and can be used to up- consumption of the quad OP470 is half that of four OP27s, a grade systems using these devices. significant advantage for power conscious applications. The For higher speed applications, the OP471, with a slew rate of 8 OP470 is unity-gain stable with a gain bandwidth product of V/ms, is recommended. 6 MHz and a slew rate of 2 V/ms.
SIMPLIFIED SCHEMATIC V+ BIAS –IN +IN V–
REV. B Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that
may result from its use. No license is granted by implication or otherwise
Tel: 781/329-4700 www.analog.com
under any patent or patent rights of Analog Devices.
Fax: 781/326-8703 © Analog Devices, Inc., 2002
Document Outline FEATURES GENERAL DESCRIPTION PIN CONNECTIONS SIMPLIFIED SCHEMATIC SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ORDERING GUIDE Typical Performance Characteristics APPLICATIONS INFORMATION Voltage and Current Noise TOTAL NOISE AND SOURCE RESISTANCE NOISE MEASUREMENTS— PEAK-TO-PEAK VOLTAGE NOISE NOISE MEASUREMENT—NOISE VOLTAGE DENSITY NOISE MEASUREMENT—CURRENT NOISE DENSITY CAPACITIVE LOAD DRIVING AND POWER SUPPLY CONSIDERATIONS UNITY-GAIN BUFFER APPLICATIONS 50k APPLICATIONS Low Noise Amplifier DIGITAL PANNING CONTROL SQUELCH AMPLIFIER FIVE-BAND LOW-NOISE STEREO GRAPHIC EQUALIZER OUTLINE DIMENSIONS Revision History
