Datasheet OP37 (Analog Devices) - 2
DescriptionLow Noise, Precision, High Speed Operational Amplifier (AVCL≥5)
Pages / Page17 / 2 — OP37* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. …
RevisionB
File Format / SizePDF / 589 Kb
OP37* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. COMPARABLE PARTS. DESIGN RESOURCES. EVALUATION KITS
OP37* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017 COMPARABLE PARTS DESIGN RESOURCES EVALUATION KITS
View a parametric search of comparable parts. • OP37 Material Declaration • PCN-PDN Information
EVALUATION KITS
• Quality And Reliability • EVAL-OPAMP-1 Evaluation Board • Symbols and Footprints
DOCUMENTATION DISCUSSIONS Application Notes
View all OP37 EngineerZone Discussions. • AN-356: User's Guide to Applying and Measuring Operational Amplifier Specifications
SAMPLE AND BUY
• AN-358: Noise and Operational Amplifier Circuits Visit the product page to see pricing options. • AN-649: Using the Analog Devices Active Filter Design Tool
TECHNICAL SUPPORT
• AN-940: Low Noise Amplifier Selection Guide for Optimal Submit a technical question or find your regional support Noise Performance number.
Data Sheet
• OP37: Low Noise, Precision, High Speed Operational
DOCUMENT FEEDBACK
Amplifier (AVCL>5) Data Sheet Submit feedback for this data sheet.
TOOLS AND SIMULATIONS
• OP37 SPICE Macro-Model
This page is dynamically generated by Analog Devices, Inc., and inserted into this data sheet. A dynamic change to the content on this page will not trigger a change to either the revision number or the content of the product data sheet. This dynamic page may be frequently modified.
Document Outline FEATURES GENERAL DESCRIPTION PIN CONNECTIONS SIMPLIFIED SCHEMATIC ABSOLUTE MAXIMUM RATINGS ORDERING GUIDE SPECIFICATIONS BINDING DIAGRAM Wafer Test Limits Typical Electrical Characteristics Typical Performance Characteristics APPLICATIONS INFORMATION Offset Voltage Adjustment Noise Measurements Optimizing Linearity Instrumentation Amplifier Comments on Noise Audio Applications OUTLINE DIMENSIONS Revision History
