Datasheet LTC1196, LTC1198 (Analog Devices) - 7
Description8-Bit, SO-8, 1Msps ADCs with Auto-Shutdown Options
Pages / Page28 / 7 — ELECTRICAL CHARACTERISTICS. Note 2:. Note 4:. Note 3:. Note 5:. TYPICAL …
File Format / SizePDF / 921 Kb
ELECTRICAL CHARACTERISTICS. Note 2:. Note 4:. Note 3:. Note 5:. TYPICAL PERFORMANCE CHARACTERISTICS. Supply Current vs Clock Rate
ELECTRICAL CHARACTERISTICS Note 2: Note 4: Note 3: Note 5: TYPICAL PERFORMANCE CHARACTERISTICS Supply Current vs Clock Rate
LTC1196/LTC1198
All voltage values are with respect to GND.
Note 4:
Total unadjusted error includes offset, full scale, linearity,
Note 3:
Integral nonlinearity is defi ned as deviation of a code from a multiplexer and hold step errors. straight line passing through the actual endpoints of the transfer curve.
Note 5:
Channel leakage current is measured after the channel selection. The deviation is measured from the center of the quantization band.
TYPICAL PERFORMANCE CHARACTERISTICS Supply Current vs Clock Rate Supply Current vs Supply Voltage Supply Current vs Sample Rate
9 14 10 TA = 25°C LT1196 VCC = 5V 8 VCC = 5V 12 7 1 LT1196 V 10 CC = 2.7V 6 ACTIVE MODE CS = 0V 5 TA = 25°C 8 CS = 0V LTC1196 0.1 LT1198 VCC = 5V 4 VREF = VCC 6 LTC1198 3 4 LT1198 VCC = 2.7V SUPPLY CURRENT (mA) VCC = 2.7V SUPPLY CURRENT (mA) SUPPLY CURRENT (mA) 0.01 2 2 SHUTDOWN MODE 1 CS = V LTC1198 CC 0.000002 T 0 A = 25°C 0 0.001 0 2 4 6 8 10 12 14 16 2.5 3.0 3.5 4.0 4.5 5.0 5.5 6.0 100 1k 10k 100k 1M FREQUENCY (MHz) SUPPLY VOLTAGE (V) SAMPLE RATE (Hz) 1196/98 G03 1196/98 G01 1196/98 G02
Supply Current vs Temperature Offset vs Reference Voltage Offset vs Supply Voltage
10 1.6 0.5 CS ) = 0V TA = 25°C TA = 25°C 9 REF V 0.4 V V 1.4 CC = 5V REF = VCC s f f 8 CLK = 12MHz 0.3 CLK = 3MHz 1 256 1.2 7 VCC = 5V 0.2 6 1.0 0.1 5 0.8 0 4 –0.1 0.6 3 –0.2 SUPPLY CURRENT (mA) 0.4 2 V –0.3 CC = 2.7V MAGNITUDE OF OFFSET (LSB) 1 0.2 –0.4 MAGNITUDE OF OFFSET (LSB = 0 0 –0.5 –55 –35 –15 5 25 45 65 85 105 125 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 2.5 3.0 3.5 4.0 4.5 5.0 5.5 6.0 TEMPERATURE (°C) REFERENCE VOLTAGE (V) SUPPLY VOLTAGE (V) 1196/98 G04 1196/98 G05 1196/98 G06 119698fb 7
