Datasheet LTC1197, LTC1197L, LTC1199, LTC1199L (Analog Devices) - 10
Description10-Bit, 500ksps ADCs in MSOP with Auto Shutdown
Pages / Page28 / 10 — PI FU CTIO S. CS (Pin 1):. DIN (Pin 5):. DOUT (Pin 6):. + IN, CH0 (Pin …
File Format / SizePDF / 317 Kb
PI FU CTIO S. CS (Pin 1):. DIN (Pin 5):. DOUT (Pin 6):. + IN, CH0 (Pin 2):. CLK (Pin 7):. – IN, CH1 (Pin 3):. VCC (Pin 8):
PI FU CTIO S CS (Pin 1): DIN (Pin 5): DOUT (Pin 6): + IN, CH0 (Pin 2): CLK (Pin 7): – IN, CH1 (Pin 3): VCC (Pin 8):
LTC1197/LTC1197L LTC1199/LTC1199L
U U U PI FU CTIO S CS (Pin 1):
Chip Select Input. A logic low on this input
DIN (Pin 5):
LTC1199/LTC1199L Digital Data Input. The enables the LTC1197/LTC1197L/LTC1199/LTC1199L. A/D configuration word is shifted into this input. Power shutdown is activated when CS is brought high.
DOUT (Pin 6):
Digital Data Output. The A/D conversion
+ IN, CH0 (Pin 2):
Analog Input. This input must be free of result is shifted out of this output. noise with respect to GND.
CLK (Pin 7):
Shift Clock. This clock synchronizes the serial
– IN, CH1 (Pin 3):
Analog Input. This input must be free of data transfer. noise with respect to GND.
VCC (Pin 8):
Positive Supply. This supply must be kept
GND (Pin 4):
Analog Ground. GND should be tied directly free of noise and ripple by bypassing directly to the to an analog ground plane. analog ground plane. For LTC1199/LTC1199L, VREF is tied internally to this pin.
VREF (Pin 5):
LTC1197/LTC1197L Reference Input. The reference input defines the span of the A/D converter and must be kept free of noise with respect to GND.
W BLOCK DIAGRA
VCC CS (D CLK IN) BIAS AND SERIAL PORT D SHUTDOWN CIRCUIT OUT + IN (CH0) CSMPL – SAR – IN (CH1) + MICROPOWER COMPARATOR CAPACITIVE DAC GND VREF PIN NAMES IN PARENTHESES REFER TO THE LTC1199/LTC1199L 10
