Datasheet LTC1273, LTC1275, LTC1276 (Analog Devices) - 3
Description12-Bit, 300ksps Sampling A/D Converters with Reference
Pages / Page24 / 3 — CO VERTER CH. ARA TERISTICS The. denotes the specifications which apply …
File Format / SizePDF / 329 Kb
CO VERTER CH. ARA TERISTICS The. denotes the specifications which apply over the full operating
CO VERTER CH ARA TERISTICS The denotes the specifications which apply over the full operating
LTC1273 LTC1275/LTC1276
U CO VERTER CH C ARA TERISTICS The
denotes the specifications which apply over the full operating temperature range, otherwise specfications are at TA = 25
C. With Internal Reference (Notes 5 and 6) LTC1273A/LTC1275A/LTC1276A LTC1273B/LTC1275B/LTC1276B PARAMETER CONDITIONS MIN TYP MAX MIN TYP MAX UNITS
Resolution (No Missing Codes) ● 12 12 Bits Integral Linearity Error (Note 7) ±1/2 ±1 LSB Commercial ● ±1/2 ±1 LSB Military ● ±3/4 ±1 LSB Differential Linearity Error Commercial ● ±3/4 ±1 LSB Military ● ±1 ±1 LSB Offset Error (Note 8) ±3 ±4 LSB ● ±4 ±6 LSB Gain Error ±10 ±15 LSB Gain Error Tempco IOUT(REFERENCE) = 0 ● ±5 ±35 ±10 ±45 ppm/°C
U W DY A IC ACCURACY (Note 5) LTC1273A/LTC1275A/LTC1276A LTC1273B/LTC1275B/LTC1276B SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
S/(N + D) Signal-to-Noise Plus Distortion Ratio 50kHz/150kHz Input Signal 72/70 dB THD Total Harmonic Distortion 50kHz/150kHz Input Signal – 83/– 74 dB Up to 5th Harmonic Peak Harmonic or Spurious Noise 50kHz/150kHz Input Signal – 85/– 76 dB IMD Intermodulation Distortion fIN1 = 29.37kHz, fIN2 = 32.446kHz – 80 dB Full Power Bandwidth 4.5 MHz Full Linear Bandwidth (S/(N + D) ≥ 68dB) 200 kHz
U U A ALOG I PUT The
C. (Note 5) LTC1273A/LTC1275A/LTC1276A LTC1273B/LTC1275B/LTC1276B SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VIN Analog Input Range (Note 9) 4.95V ≤ VDD ≤ 5.25V (LTC1273) ● 0 to 5 V 4.75V ≤ VDD ≤ 5.25V, – 5.25V ≤ VSS ≤ – 2.45V (LTC1275) ● ±2.5 V 4.95V ≤ VDD ≤ 5.25V, – 5.25V ≤ VSS ≤ – 4.95V (LTC1276) ● ±5 V IIN Analog Input Leakage Current CS = High ● ±1 µA CIN Analog Input Capacitance Between Conversions (Sample Mode) 50 pF During Conversions (Hold Mode) 5 pF tACQ Sample-and-Hold Commercial ● 600 ns Acquisition Time Military ● 1000 ns
U U U I TER AL REFERE CE CHARACTERISTICS The
C. (Note 5) LTC1273A/LTC1275A/LTC1276A LTC1273B/LTC1275B/LTC1276B PARAMETER CONDITIONS MIN TYP MAX MIN TYP MAX UNITS
VREF Output Voltage IOUT = 0 2.400 2.420 2.440 2.400 2.420 2.440 V VREF Output Tempco IOUT = 0 ● ±5 ±25 ±10 ±45 ppm/°C VREF Line Regulation 4.95V ≤ VDD ≤ 5.25V 0.01 0.01 LSB/V – 5.25V ≤ VSS ≤ – 4.95V 0.01 0.01 LSB/V VREF Load Regulation 0V ≤ |IOUT| ≤ 1mA 2 2 LSB/mA 127356fa 3
