Datasheet LTC1290 (Analog Devices) - 4
DescriptionSingle Chip 12-Bit Data Acquisition System
Pages / Page32 / 4 — AC CHARACTERISTICS The. denotes the specifications which apply over the …
File Format / SizePDF / 633 Kb
AC CHARACTERISTICS The. denotes the specifications which apply over the full operating temperature range,
AC CHARACTERISTICS The denotes the specifications which apply over the full operating temperature range,
LTC1290
C. (Note 3) LTC1290B/LTC1290C/LTC1290D SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
fSCLK Shift Clock Frequency VCC = 5V (Note 6) 0 2.0 MHz fACLK A/D Clock Frequency VCC = 5V (Note 6) (Note 10) 4.0 MHz tACC Delay Time from CS↓ to DOUT Data Valid (Note 9) 2 ACLK Cycles tSMPL Analog Input Sample Time See Operating Sequence 7 SCLK Cycles tCONV Conversion Time See Operating Sequence 52 ACLK Cycles tCYC Total Cycle Time See Operating Sequence (Note 6) 12 SCLK + Cycles 56 ACLK tdDO Delay Time, SCLK↓ to DOUT Data Valid See Test Circuits LTC1290BC, LTC1290CC ● 130 220 ns LTC1290DC, LTC1290BI LTC1290CI, LTC1290DI LTC1290BM, LTC1290CM ● 180 270 ns LTC1290DM
(OBSOLETE)
tdis Delay Time, CS↑ to DOUT Hi-Z See Test Circuits ● 70 100 ns ten Delay Time, 2nd ACLK↓ to DOUT Enabled See Test Circuits ● 130 200 ns thCS Hold Time, CS After Last SCLK↓ VCC = 5V (Note 6) 0 ns thDI Hold Time, DIN After SCLK↑ VCC = 5V (Note 6) 50 ns thDO Time Output Data Remains Valid After SCLK↓ 50 ns tf DOUT Fall Time See Test Circuits ● 65 130 ns tr DOUT Rise Time See Test Circuits ● 25 50 ns tsuDI Setup Time, DIN Stable Before SCLK↑ VCC = 5V (Note 6) 50 ns tsuCS Setup Time, CS↓ Before Clocking in (Notes 6, 9) 2 ACLK Cycles First Address Bit + 100ns tWHCS CS High Time During Conversion VCC = 5V (Note 6) 52 ACLK Cycles CIN Input Capacitance Analog Inputs On Channel 100 pF Analog Inputs Off Channel 5 pF Digital Inputs 5 pF 1290fe 4
