Datasheet LTC1405 (Analog Devices) - 5
Description12-Bit, 5Msps, Sampling ADC
Pages / Page20 / 5 — ELECTRICAL CHARACTERISTICS Note 6:. Note 8:. Note 7:. Note 9:. Note 10:. …
File Format / SizePDF / 337 Kb
ELECTRICAL CHARACTERISTICS Note 6:. Note 8:. Note 7:. Note 9:. Note 10:. TYPICAL PERFORMANCE CHARACTERISTICS
ELECTRICAL CHARACTERISTICS Note 6: Note 8: Note 7: Note 9: Note 10: TYPICAL PERFORMANCE CHARACTERISTICS
LTC1405
Dynamic specifications are guaranteed for dual supply operation
Note 8:
Bipolar offset is the offset voltage measured from –0.5LSB with a single-ended + AIN input and – AIN grounded. For single supply when the output code flickers between 0000 0000 0000 and dynamic specifications, refer to the Typical Performance Characteristics. 1111 1111 1111.
Note 7:
Integral nonlinearity is defined as the deviation of a code from a
Note 9:
Guaranteed by design, not subject to test. straight line passing through the actual endpoints of the transfer curve.
Note 10:
Recommended operating conditions. The deviation is measured from the center of the quantization band.
W U TYPICAL PERFORMANCE CHARACTERISTICS S/(N+D) vs Input Frequency Spurious-Free Dynamic Range and Amplitude vs Input Amplitude Distortion vs Input Frequency
75 100 –50 dBFS DUAL SUPPLIES VIN = 0dB –55 ±2.048V RANGE 90 GAIN = 1× 70 –60 AIN = 0dBFS VIN = –6dB 80 –65 65 dBc –70 70 DUAL SUPPLIES –75 60 ±2.048V RANGE S/(N + D) (dB) GAIN = 1× 60 DISTORTION (dB) –80 SFDR (dBc AND dBFS) THD DUAL SUPPLIES –85 55 ±2.048V RANGE V 50 3RD 2ND IN = –20dB GAIN = 1× –90 fIN = 2.5MHz 50 40 –95 0.1 1 10 100 –50 –40 –30 –20 –10 0 0 1 10 100 INPUT FREQUENCY (MHz) INPUT AMPLITUDE (dBFS) INPUT FREQUENCY (MHz) 1405 G01 1405 G02 1405 G03
75 100 –50 SINGLE SUPPLY SINGLE SUPPLY dBFS –55 V ±1.024V RANGE ±1.024V RANGE IN = 0dB GAIN = 2 90 GAIN = 2 70 × × –60 AIN = 0dBFS V –65 IN = –6dB 80 65 dBc –70 70 –75 60 S/(N + D) (dB) 60 DISTORTION (dB) –80 SFDR (dBc AND dBFS) THD 3RD SINGLE SUPPLY 55 –85 50 ±1.024V RANGE 2ND V GAIN = 2× –90 IN = –20dB fIN = 2.5MHz 50 40 –95 0.1 1 10 100 –50 –40 –30 –20 –10 0 0 1 10 100 INPUT FREQUENCY (MHz) INPUT AMPLITUDE (dBFS) INPUT FREQUENCY (MHz) 1405 G04 1405 G05 1405 G06 1405fa 5
