LTC1405 UUUPI FU CTIO S+ AIN (Pin 1): Positive Analog Input. OGND (Pin 21): Output Logic Ground. Tie to GND. – AIN (Pin 2): Negative Analog Input. OVDD (Pin 22): Positive Supply for the Output Logic. Connect to Pin 23 for 5V logic. If not shorted to Pin 23, VCM (Pin 3): 2.5V Reference Output.Optional input com- bypass to GND with a 1 mon mode for single supply operation. Bypass to GND µF ceramic. with a 1µF to 10µF ceramic. VDD (Pin 23): Analog 5V Supply. Bypass to GND with a 1µF ceramic. SENSE (Pin 4): Reference Programming Pin. Ground selects VREF = 4.096V. Short to VREF for 2.048V. Connect GND (Pin 24): Analog Power Ground. SENSE to VDD to drive VREF with an external reference. VSS (Pin 25): Negative Supply. Can be – 5V or 0V. If VSS is VREF (Pin 5): DAC Reference. Bypass to GND with a 1µF to not shorted to GND, bypass to GND with a 1µF ceramic. 10µF ceramic. CLK (Pin 26): Conversion Start Signal. This active high GND (Pin 6): DAC Reference Ground. signal starts a conversion on its rising edge. VDD (Pin 7): Analog 5V Supply. Bypass to GND with a 1µF OF (Pin 27): Overflow Output. This signal is high when the to 10µF ceramic. digital output is 011111111111 or 100000000000. GND (Pin 8): Analog Power Ground. GAIN (Pin 28): Gain Select for Input PGA. 5V selects an input gain of 1, 0V selects a gain of 2. D11 to D0 (Pins 9 to 20): Data Outputs. The output format is two’s complement. 1405fa 7
