Datasheet LTC1603 (Analog Devices)
DescriptionHigh Speed, 16-Bit, 250ksps Sampling A/D Converter with Shutdown
Pages / Page20 / 1 — FEATURES. DESCRIPTIO. A Complete, 250ksps 16-Bit ADC. 90dB S/(N+D) and …
File Format / SizePDF / 261 Kb
FEATURES. DESCRIPTIO. A Complete, 250ksps 16-Bit ADC. 90dB S/(N+D) and –100dB THD (Typ). Power Dissipation: 220mW (Typ)
Datasheet LTC1603 Analog Devices
LTC1603 High Speed, 16-Bit, 250ksps Sampling A/D Converter with Shutdown
U FEATURES DESCRIPTIO
The LTC®1603 is a 250ksps, 16-bit sampling A/D con- ■
verter that draws only 220mW from ±5V supplies. This ■
high performance device includes a high dynamic range ■
Nap (7mW) and Sleep (10
µ
W) Shutdown Modes
sample-and-hold, a precision reference and a high speed ■ No Pipeline Delay parallel output. Two digitally selectable power shutdown ■ No Missing Codes over Temperature modes provide power savings for low power systems. ■ Operates with Internal 15ppm/°C Reference The LTC1603’s full-scale input range is ± 2.5V. Outstand- or External Reference ing AC performance includes 90dB S/(N+D) and – 100dB ■ True Differential Inputs Reject Common Mode Noise THD at a sample rate of 250ksps. ■ 5MHz Full Power Bandwidth ■ The unique differential input sample-and-hold can acquire ±2.5V Bipolar Input Range ■ Pin Compatible with LTC1604 and LTC1608 single-ended or differential input signals up to its 15MHz ■ 36-Pin SSOP Package bandwidth. The 68dB common mode rejection allows users to eliminate ground loops and common mode noise
U
by measuring signals differentially from the source.
APPLICATIO S
The ADC has µP compatible,16-bit parallel output port. ■ Telecommunications There is no pipeline delay in conversion results. A separate ■ Digital Signal Processing convert start input and a data ready signal (BUSY) ease ■ Multiplexed Data Acquisition Systems connections to FlFOs, DSPs and microprocessors. ■ High Speed Data Acquisition , LTC and LT are registered trademarks of Linear Technology Corporation. ■ Spectrum Analysis ■ Imaging Systems
U TYPICAL APPLICATIO
2.2µF 10µF 5V 10µF 5V 10µF 10Ω + + + 3 36 35 9 10 V AV REF DD AVDD DVDD DGND SHDN 33 CS 32 CONTROL µP LOGIC CONVST 31 REFCOMP CONTROL 4 7.5k AND 2.5V RD 30 1.75X LINES TIMING + 4.375V REF BUSY 27 47µF OVDD 29 5V OR + 3V 10µF + OGND 28 1 AIN + DIFFERENTIAL 16-BIT OUTPUT ANALOG INPUT B15 TO B0 – SAMPLING 16-BIT ± BUFFERS 2.5V 2 AIN ADC – D15 TO D0 PARALLEL BUS 11 TO 26 AGND AGND AGND AGND VSS 1603 TA01 5 6 7 8 34 10µF + –5V 1603f 1
