LTC1747 UUUPI FU CTIO SSENSE (Pin 1): Reference Sense Pin. Ground selects ±1V. MSBINV (Pin 22): MSB Inversion Control. Low inverts VDD selects ±1.6V. Greater than 1V and less than 1.6V the MSB, 2’s complement output format. High does not applied to the SENSE pin selects an input range of ±VSENSE, invert the MSB, offset binary output format. ±1.6V is the largest valid input range. ENC (Pin 23): Encode Input. The input sample starts on the VCM (Pin 2): 2.35V Output and Input Common Mode Bias. positive edge. Bypass to ground with 4.7µF ceramic chip capacitor. ENC (Pin 24): Encode Complement Input. Conversion GND (Pins 3, 6, 9, 12, 13, 16, 19, 21, 36, 37): ADC Power starts on the negative edge. Bypass to ground with 0.1µF Ground. ceramic for single-ended ENCODE signal. A +IN (Pin 4): Positive Differential Analog Input. OE (Pin 25): Output Enable. Low enables outputs. Logic A – high makes outputs Hi-Z. OE should not exceed the IN (Pin 5): Negative Differential Analog Input. voltage on 0V V DD. DD (Pins 7, 8, 17, 18, 20): 5V Supply. Bypass to AGND with 1µF ceramic chip capacitors. CLKOUT (Pin 26): Data Valid Output. Latch data on the rising edge of CLKOUT. REFLB (Pin 10): ADC Low Reference. Bypass to Pin 11 with 0.1µF ceramic chip capacitor. Do not connect to OGND (Pins 27, 38, 47): Output Driver Ground. Pin␣ 14. NC (Pins 28, 29): Do not connect these pins. REFHA (Pin 11): ADC High Reference. Bypass to Pin 10 with D0-D1 (Pins 30 to 31): Digital Outputs. 0.1µF ceramic chip capacitor, to Pin 14 with a 4.7µF ceramic OVDD (Pins 32, 43): Positive Supply for the Output Driv- capacitor and to ground with 1µF ceramic capacitor. ers. Bypass to ground with 0.1µF ceramic chip capacitor. REFLA (Pin 14): ADC Low Reference. Bypass to Pin 15 with D2-D4 (Pins 33 to 35): Digital Outputs. 0.1µF ceramic chip capacitor, to Pin 11 with a 4.7µF ce- D5-D8 (Pins 39 to 42): Digital Outputs. ramic capacitor and to ground with 1µF ceramic capacitor. D9-D11 (Pins 44 to 46): Digital Outputs. REFHB (Pin 15): ADC High Reference. Bypass to Pin 14 with 0.1µF ceramic chip capacitor. Do not connect to OF (Pin 48): Over/Under Flow Output. High when an over Pin␣ 11. or under flow has occurred. 1747fa 9
