LTC1864/LTC1865 PIN FUNCTIONSLTC1864VREF (Pin 1): Reference Input. The reference input defi nes powers down. A logic low on this input enables the SDO the span of the A/D converter and must be kept free of pin, allowing the data to be shifted out. noise with respect to GND. SDO (Pin 6): Digital Data Output. The A/D conversion IN+, IN– (Pins 2, 3): Analog Inputs. These inputs must result is shifted out of this pin. be free of noise with respect to GND. SCK (Pin 7): Shift Clock Input. This clock synchronizes GND (Pin 4): Analog Ground. GND should be tied directly the serial data transfer. to an analog ground plane. VCC (Pin 8): Positive Supply. This supply must be kept CONV (Pin 5): Convert Input. A logic high on this input free of noise and ripple by bypassing directly to the starts the A/D conversion process. If the CONV input is analog ground plane. left high after the A/D conversion is fi nished, the part LTC1865 (MSOP Package)CONV (Pin 1): Convert Input. A logic high on this input SDO (Pin 7): Digital Data Output. The A/D conversion starts the A/D conversion process. If the CONV input is result is shifted out of this output. left high after the A/D conversion is fi nished, the part SCK (Pin 8): Shift Clock Input. This clock synchronizes powers down. A logic low on this input enables the SDO the serial data transfer. pin, allowing the data to be shifted out. VCH0, CH1 (Pins 2, 3): Analog Inputs. These inputs must CC (Pin 9): Positive Supply. This supply must be kept free of noise and ripple by bypassing directly to the be free of noise with respect to AGND. analog ground plane. AGND (Pin 4): Analog Ground. AGND should be tied directly V to an analog ground plane. REF (Pin 10): Reference Input. The reference input defi nes the span of the A/D converter and must be kept free of DGND (Pin 5): Digital Ground. DGND should be tied directly noise with respect to AGND. to an analog ground plane. SDI (Pin 6): Digital Data Input. The A/D confi guration word is shifted into this input. LTC1865 (SO-8 Package)CONV (Pin 1): Convert Input. A logic high on this input SDI (Pin 5): Digital Data Input. The A/D confi guration starts the A/D conversion process. If the CONV input is word is shifted into this input. left high after the A/D conversion is fi nished, the part SDO (Pin 6): Digital Data Output. The A/D conversion powers down. A logic low on this input enables the SDO result is shifted out of this output. pin, allowing the data to be shifted out. SCK (Pin 7): Shift Clock Input. This clock synchronizes CH0, CH1 (Pins 2, 3): Analog Inputs. These inputs must the serial data transfer. be free of noise with respect to GND. VGND (Pin 4): Analog Ground. GND should be tied directly CC (Pin 8): Positive Supply. This supply must be kept free of noise and ripple by bypassing directly to the analog to an analog ground plane. ground plane. VREF is tied internally to this pin. 18645fb 10
