Datasheet LTC2107 (Analog Devices) - 9
Description | 16-Bit, 210Msps High Performance ADC |
Pages / Page | 32 / 9 — typical perFormance characteristics. Integral Nonlinearity (INL). … |
File Format / Size | PDF / 514 Kb |
typical perFormance characteristics. Integral Nonlinearity (INL). Differential Nonlinearity (DNL). vs Output Code
LTC2107
typical perFormance characteristics Integral Nonlinearity (INL) Differential Nonlinearity (DNL) vs Output Code vs Output Code AC Grounded Input Histogram
2.0 1.00 10000 1.5 0.75 1.0 0.50 6667 0.5 0.25 0 0 COUNT –0.5 –0.25 INL ERROR (LSB) DNL ERROR (LSB) 3333 –1.0 –1.50 –1.5 –1.75 –2.0 –2.00 0 0 16384 32768 49152 65536 0 16384 32768 49152 65536 32799 32809 32819 OUTPUT CODE OUTPUT CODE OUTPUT CODE 2107 G01 2107 G02 2107 G03
128k Point FFT, fIN = 5.0MHz, 128k Point FFT, fIN = 30.6MHz, 128k Point FFT, 30.6MHz, –1dBFS, PGA = 0, Dither On –1dBFS, PGA = 0, Dither On –20dBFS, PGA = 0, Dither Off
0 0 0 –10 –10 –10 –20 –20 –20 –30 –30 –30 –40 –40 –40 –50 –50 –50 –60 –60 –60 –70 –70 –70 –80 –80 –80 –90 –90 AMPLITUDE (dBFS) –90 AMPLITUDE (dBFS) –100 AMPLITUDE (dBFS) –100 –100 –110 –110 –110 –120 –120 –120 –130 –130 –130 –140 –140 0 15 30 45 60 75 90 105 0 15 30 45 60 75 90 105 0 15 30 45 60 75 90 105 FREQUENCY (MHz) FREQUENCY (MHz) FREQUENCY (MHz) 2107 G04 2107 G05 2107 G06
128k Point 2-Tone FFT, 128k Point 2-Tone FFT, 128k Point FFT, 30.6MHz,–20dBFS, 25.1MHz and 30.51MHz, 25.07MHz and 30.5MHz, PGA = 0, Dither On –7dBFS PGA = 0, Dither On –20dBFS PGA = 0, Dither On
0 0 0 –10 –10 –10 –20 –20 –20 –30 –30 –30 –40 –40 –40 –50 –50 –50 –60 –60 –60 –70 –70 –80 –70 –90 –80 –80 AMPLITUDE (dBFS) –100 AMPLITUDE (dBFS) –90 AMPLITUDE (dBFS) –90 –110 –100 –100 –120 –110 –110 –130 –120 –120 –140 –130 –130 0 15 30 45 60 75 90 105 0 15 30 45 60 75 90 105 0 15 30 45 60 75 90 105 FREQUENCY (MHz) FREQUENCY (MHz) FREQUENCY (MHz) 2107 G07 2107 G08 2107 G09 2107fb For more information www.linear.com/LTC2107 9 Document Outline Features Applications Description Block Diagram Absolute Maximum Ratings Pin Configuration Order Information Converter Characteristics Analog Input Dynamic Accuracy VCM Output Digital Inputs and OUtputs Power Requirements Timing Characteristics Timing Diagrams Typical Performance Characteristics Pin Functions Block Diagram Applications Information Package Description Typical Application Related Parts
