LTC2162/LTC2161/LTC2160 DynaMic accuracyThe l denotes the specifications which apply over the full operating temperature range,otherwise specifications are at TA = 25°C. AIN = –1dBFS. (Note 5)LTC2162LTC2161LTC2160SYMBOL PARAMETERCONDITIONSMINTYPMAXMINTYPMAXMINTYPMAXUNITS SFDR Spurious Free Dynamic Range 5MHz Input 90 90 90 dBFS 3rd Harmonic 30MHz Input l 83 90 84 90 84 90 dBFS 70MHz Input 89 89 89 dBFS 140MHz Input 84 84 84 dBFS SFDR Spurious Free Dynamic Range 5MHz Input 95 95 95 dBFS 4th Harmonic or Higher 30MHz Input l 88 95 89 95 89 95 dBFS 70MHz Input 95 95 95 dBFS 140MHz Input 95 95 95 dBFS S/(N+D) Signal-to-Noise Plus 5MHz Input 76.8 76.7 76.9 dBFS Distortion Ratio 30MHz Input l 75 76.7 75 76.6 74.9 76.8 dBFS 70MHz Input 76.4 76.3 76.5 dBFS 140MHz Input 76.3 75.2 76.4 dBFS inTernal reFerence characTerisTicsThe l denotes the specifications which apply over thefull operating temperature range, otherwise specifications are at TA = 25°C. (Note 5) PARAMETERCONDITIONSMINTYPMAXUNITS VCM Output Voltage IOUT = 0 0.5•VDD – 25mV 0.5•VDD 0.5•VDD + 25mV V VCM Output Temperature Drift ±25 ppm/°C VCM Output Resistance –600µA < IOUT < 1mA 4 Ω VREF Output Voltage IOUT = 0 1.225 1.250 1.275 V VREF Output Temperature Drift ±25 ppm/°C VREF Output Resistance –400µA < IOUT < 1mA 7 Ω VREF Line Regulation 1.7V < VDD < 1.9V 0.6 mV/V DigiTal inpuTs anD ouTpuTsThe l denotes the specifications which apply over the full operatingtemperature range, otherwise specifications are at TA = 25°C. (Note 5) SYMBOLPARAMETERCONDITIONSMINTYPMAXUNITSENCODE INPUTS (ENC+, ENC–) DIFFERENTIAL ENCODE MODE (ENC– NOT TIED TO GND) VID Differential Input Voltage (Note 8) l 0.2 V VICM Common Mode Input Voltage Internally Set 1.2 V Externally Set (Note 8) l 1.1 1.6 V VIN Input Voltage Range ENC+, ENC– to GND l 0.2 3.6 V RIN Input Resistance (See Figure 10) 10 kΩ CIN Input Capacitance (Note 8) 3.5 pF SINGLE-ENDED ENCODE MODE (ENC– TIED TO GND) VIH High Level Input Voltage VDD = 1.8V l 1.2 V VIL Low Level Input Voltage VDD = 1.8V l 0.6 V VIN Input Voltage Range ENC+ to GND l 0 3.6 V RIN Input Resistance (See Figure 11) 30 kΩ CIN Input Capacitance (Note 8) 3.5 pF 216210f 5 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Converter Characteristics Analog input Dynamic Accuracy Internal Reference Characteristics Digital Inputs and Outputs Power Requirements Timing Characteristics Electrical Characteristics Timing Diagrams Typical Performance Characteristics Pin Functions Functional Block Diagram Applications Information Typical Applications Package Description Typical Application Related Parts
