Datasheet LT5534 (Analog Devices) - 6
Description50MHz to 3GHz RF Power Detector with 60dB Dynamic Range
Pages / Page10 / 6 — PIN FUNCTIONS EN (Pin 1):. VCC (Pin 4):. RF (Pin 6):. GND (Pins 2, 5):. …
PIN FUNCTIONS EN (Pin 1):. VCC (Pin 4):. RF (Pin 6):. GND (Pins 2, 5):. OUT (Pin 3):. BLOCK DIAGRAM. TEST CIRCUIT
PIN FUNCTIONS EN (Pin 1): VCC (Pin 4): RF (Pin 6): GND (Pins 2, 5): OUT (Pin 3): BLOCK DIAGRAM TEST CIRCUIT
LT5534
Enable. When the input voltage is higher than
VCC (Pin 4):
Power Supply. This pin should be decoupled 0.9V, the circuit is completely turned on. When the input using 100pF and 0.1µF capacitors. voltage is less than 0.6V, the circuit is turned off.
RF (Pin 6):
RF Input. This pin is internally biased to
GND (Pins 2, 5):
Ground. VCC – 0.18V. A coupling capacitor must be used to connect
V
to the RF signal source.
OUT (Pin 3):
RF Detector Output.
BLOCK DIAGRAM
4 VCC DET DET DET DET DET + VOUT RF LIMITER RF LIMITER RF LIMITER RF LIMITER 3 RF – 6 VREF OFFSET COMP BIAS GND EN 2 5 1 5534 BD
TEST CIRCUIT
C1 1nF 1 6 EN EN RF J1 LT5534 RF R1 R2 2 5 47Ω 0Ω GND GND OPTIONAL OPTIONAL 3 4 VOUT VOUT VCC VCC C5 C3 C2 OPTIONAL 100pF 0.1µF 5534 F01
REF DES VALUE SIZE PART NUMBER
C1 1nF 0402 AVX 04025C102JAT2A C2 0.1µF 0603 TAIYO YUDEN TMK107BJ104KA C3 100pF 0603 AVX 06035C101KAT2A C5 0603 OPTIONAL R1 47Ω 0402 OPTIONAL R2 0Ω 0603 OPTIONAL
Figure 1. Evaluation Circuit Schematic
5534fc 6 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram TEST CIRCUIT Applications Information Revision History Package Description Related Parts
