Datasheet LTC2229 (Analog Devices) - 2
Description12-Bit, 80Msps Low Power 3V ADC
Pages / Page24 / 2 — ABSOLUTE AXI U. RATI GS. PACKAGE/ORDER I FOR ATIO. OVDD = VDD (Notes 1, …
File Format / SizePDF / 566 Kb
ABSOLUTE AXI U. RATI GS. PACKAGE/ORDER I FOR ATIO. OVDD = VDD (Notes 1, 2). Order Options. CO VERTER CHARACTERISTICS The
ABSOLUTE AXI U RATI GS PACKAGE/ORDER I FOR ATIO OVDD = VDD (Notes 1, 2) Order Options CO VERTER CHARACTERISTICS The
LTC2229
W W W U U W U ABSOLUTE AXI U RATI GS PACKAGE/ORDER I FOR ATIO OVDD = VDD (Notes 1, 2)
Supply Voltage (VDD) ... 4V TOP VIEW Digital Output Ground Voltage (OGND) ... –0.3V to 1V DD CM V V SENSE MODE OF D11 D10 D9 Analog Input Voltage (Note 3) ... –0.3V to (VDD + 0.3V) 32 31 30 29 28 27 26 25 Digital Input Voltage .. –0.3V to (VDD + 0.3V) AIN+ 1 24 D8 Digital Output Voltage .. –0.3V to (OVDD + 0.3V) AIN– 2 23 D7 Power Dissipation .. 1500mW REFH 3 22 D6 Operating Temperature Range REFH 4 21 OVDD 33 LTC2229C ... 0°C to 70°C REFL 5 20 OGND REFL 6 19 D5 LTC2229I ...–40°C to 85°C V 7 18 DD D4 Storage Temperature Range ..–65°C to 125°C GND 8 17 D3 9 10 11 12 13 14 15 16 OE CLK NC NC D0 D1 D2 SHDN UH PACKAGE 32-LEAD (5mm × 5mm) PLASTIC QFN TJMAX = 125°C, θJA = 34°C/W EXPOSED PAD IS GND (PIN 33) MUST BE SOLDERED TO PCB ORDER PART NUMBER QFN PART MARKING* LTC2229CUH 2229 LTC2229IUH
Order Options
Tape and Reel: Add #TR Lead Free: Add #PBF Lead Free Tape and Reel: Add #TRPBF Lead Free Part Marking: http://www.linear.com/leadfree/ Consult LTC Marketing for parts specified with wider operating temperature ranges. *The temperature grade is identified by a label on the shipping container.
U CO VERTER CHARACTERISTICS The
C. (Note 4) PARAMETER CONDITIONS MIN TYP MAX UNITS
Resolution (No Missing Codes) ● 12 Bits Integral Linearity Error Differential Analog Input (Note 5) ● –1.1 ±0.4 1.1 LSB Differential Linearity Error Differential Analog Input ● –0.8 ±0.2 0.8 LSB Offset Error (Note 6) ● –12 ±2 12 mV Gain Error External Reference ● –2.5 ±0.5 2.5 %FS Offset Drift ±10 µV/°C Full-Scale Drift Internal Reference ±30 ppm/°C External Reference ±5 ppm/°C Transition Noise SENSE = 1V 0.3 LSBRMS 2229fa 2
