Datasheet LTC2245 (Analog Devices) - 10
Description14-Bit, 10Msps Low Power 3V ADC
Pages / Page20 / 10 — APPLICATIO S I FOR ATIO. Aperture Delay Time. Aperture Delay Jitter. …
File Format / SizePDF / 528 Kb
APPLICATIO S I FOR ATIO. Aperture Delay Time. Aperture Delay Jitter. SAMPLE/HOLD OPERATION AND INPUT DRIVE. CONVERTER OPERATION
APPLICATIO S I FOR ATIO Aperture Delay Time Aperture Delay Jitter SAMPLE/HOLD OPERATION AND INPUT DRIVE CONVERTER OPERATION
LTC2245
U U W U APPLICATIO S I FOR ATIO Aperture Delay Time
the second stage produces its residue which is acquired by the third stage. An identical process is repeated for the The time from when CLK reaches mid-supply to the instant third, fourth and fifth stages, resulting in a fifth stage that the input signal is held by the sample and hold circuit. residue that is sent to the sixth stage ADC for final
evaluation. The variation in the aperture delay time from conversion to Each ADC stage following the first has additional range to conversion. This random variation will result in noise accommodate flash and amplifier offset errors. Results when sampling an AC input. The signal to noise ratio due from all of the ADC stages are digitally synchronized such to the jitter alone will be: that the results can be properly combined in the correction logic before being sent to the output buffer. SNRJITTER = –20log (2π • fIN • tJITTER)
As shown in Figure 1, the LTC2245 is a CMOS pipelined
Sample/Hold Operation
multistep converter. The converter has six pipelined ADC Figure 2 shows an equivalent circuit for the LTC2245 stages; a sampled analog input will result in a digitized CMOS differential sample-and-hold. The analog inputs are value five cycles later (see the Timing Diagram section). connected to the sampling capacitors (CSAMPLE) through For optimal AC performance the analog inputs should be NMOS transistors. The capacitors shown attached to each driven differentially. For cost sensitive applications, the input (CPARASITIC) are the summation of all other capaci- analog inputs can be driven single-ended with slightly tance associated with each input. worse harmonic distortion. The CLK input is single-ended. The LTC2245 has two phases of operation, determined by LTC2245 the state of the CLK input pin. VDD CSAMPLE Each pipelined stage shown in Figure 1 contains an ADC, 4pF 15Ω A a reconstruction DAC and an interstage residue amplifier. IN+ CPARASITIC In operation, the ADC quantizes the input to the stage and 1pF VDD C the quantized value is subtracted from the input by the SAMPLE 4pF 15Ω DAC to produce a residue. The residue is amplified and AIN– CPARASITIC output by the residue amplifier. Successive stages operate 1pF out of phase so that when the odd stages are outputting VDD their residue, the even stages are acquiring that residue CLK and vice versa. When CLK is low, the analog input is sampled differentially 2245 F02 directly onto the input sample-and-hold capacitors, inside
Figure 2. Equivalent Input Circuit
the “Input S/H” shown in the block diagram. At the instant that CLK transitions from low to high, the sampled input is During the sample phase when CLK is low, the transistors held. While CLK is high, the held input voltage is buffered connect the analog inputs to the sampling capacitors and by the S/H amplifier which drives the first pipelined ADC they charge to and track the differential input voltage. stage. The first stage acquires the output of the S/H during When CLK transitions from low to high, the sampled input this high phase of CLK. When CLK goes back low, the first voltage is held on the sampling capacitors. During the hold stage produces its residue which is acquired by the phase when CLK is high, the sampling capacitors are second stage. At the same time, the input S/H goes back disconnected from the input and the held voltage is passed to acquiring the analog input. When CLK goes back high, to the ADC core for processing. As CLK transitions from 2245fa 10
