LTC2248/LTC2247/LTC2246 UUUI TER AL REFERE CE CHARACTERISTICS (Note 4)PARAMETERCONDITIONSMINTYPMAXUNITS VCM Output Voltage IOUT = 0 1.475 1.500 1.525 V VCM Output Tempco ±25 ppm/°C VCM Line Regulation 2.7V < VDD < 3.4V 3 mV/V VCM Output Resistance –1mA < I UU OUT < 1mA 4 Ω DIGITAL I PUTS A D DIGITAL OUTPUTS The ● denotes the specifications which apply over thefull operating temperature range, otherwise specifications are at TA = 25 ° C. (Note 4)SYMBOLPARAMETERCONDITIONSMINTYPMAXUNITSLOGIC INPUTS (CLK, OE, SHDN) VIH High Level Input Voltage VDD = 3V ● 2 V VIL Low Level Input Voltage VDD = 3V ● 0.8 V IIN Input Current VIN = 0V to VDD ● –10 10 µA CIN Input Capacitance (Note 7) 3 pF LOGIC OUTPUTSOVDD = 3V COZ Hi-Z Output Capacitance OE = High (Note 7) 3 pF ISOURCE Output Source Current VOUT = 0V 50 mA ISINK Output Sink Current VOUT = 3V 50 mA VOH High Level Output Voltage IO = –10µA 2.995 V IO = –200µA ● 2.7 2.99 V VOL Low Level Output Voltage IO = 10µA 0.005 V IO = 1.6mA ● 0.09 0.4 V OVDD = 2.5V VOH High Level Output Voltage IO = –200µA 2.49 V VOL Low Level Output Voltage IO = 1.6mA 0.09 V OVDD = 1.8V VOH High Level Output Voltage IO = –200µA 1.79 V VOL Low Level Output Voltage IO = 1.6mA 0.09 V WUPOWER REQUIRE E TS The ● denotes the specifications which apply over the full operating temperaturerange, otherwise specifications are at TA = 25 ° C. (Note 8)LTC2248LTC2247LTC2246SYMBOLPARAMETERCONDITIONSMINTYPMAXMINTYPMAXMINTYPMAXUNITS VDD Analog Supply (Note 9) ● 2.7 3 3.4 2.7 3 3.4 2.7 3 3.4 V Voltage OVDD Output Supply (Note 9) ● 0.5 3 3.6 0.5 3 3.6 0.5 3 3.6 V Voltage IVDD Supply Current ● 68.3 80 40 48 25 30 mA PDISS Power Dissipation ● 205 240 120 144 75 90 mW PSHDN Shutdown Power SHDN = H, 2 2 2 mW OE = H, No CLK PNAP Nap Mode Power SHDN = H, 15 15 15 mW OE = L, No CLK 224876fa 4
