Datasheet LTC2246H (Analog Devices) - 2
Description14-Bit, 25Msps 125°C ADC In LQFP
Pages / Page18 / 2 — ABSOLUTE MAXIMUM RATINGS. PACKAGE/ORDER INFORMATION. OVDD = VDD (Notes 1, …
File Format / SizePDF / 205 Kb
ABSOLUTE MAXIMUM RATINGS. PACKAGE/ORDER INFORMATION. OVDD = VDD (Notes 1, 2). ORDER INFORMATION. LEAD FREE FINISH. PART MARKING
ABSOLUTE MAXIMUM RATINGS PACKAGE/ORDER INFORMATION OVDD = VDD (Notes 1, 2) ORDER INFORMATION LEAD FREE FINISH PART MARKING
LTC2246H
TOP VIEW Supply Voltage (VDD) ..4V Digital Output Ground Voltage (OGND) .. –0.3V to 1V DD DD CM CM GND V V V V SENSE MODE OF D13 D12 D11 GND Analog Input Voltage (Note 3) ...–0.3V to (V 48 47 46 45 44 43 42 41 40 39 38 37 DD + 0.3V) Digital Input Voltage ..–0.3V to (VDD + 0.3V) Digital Output Voltage .. –0.3V to (OVDD + 0.3V) GND 1 36 GND + Power Dissipation ...1500mW A 2 35 IN D10 A – 3 34 IN D9 Operating Temperature Range.. –40°C to 125°C GND 4 33 D8 REFH 5 32 GND Storage Temperature Range ... –65°C to 150°C REFH 6 31 OVDD REFL 7 30 OGND REFL 8 29 GND GND 9 28 D7 V 10 27 DD D6 V 11 26 DD D5 V 12 25 DD GND 13 14 15 16 17 18 19 20 21 22 23 24 OE D0 D1 D2 D3 D4 GND CLK GND GND GND SHDN LX PACKAGE 48-LEAD (7mm s 7mm) PLASTIC LQFP TJMAX = 150°C, θJA = 53°C/W
ORDER INFORMATION LEAD FREE FINISH PART MARKING PACKAGE DESCRIPTION TEMPERATURE RANGE
LTC2246HLX#PBF LTC2246LX 48-Lead (7mm × 7mm) Plastic LQFP –40°C to 125°C
LEAD BASED FINISH PART MARKING PACKAGE DESCRIPTION TEMPERATURE RANGE
LTC2246HLX LTC2246LX 48-Lead (7mm × 7mm) Plastic LQFP –40°C to 125°C Consult LTC Marketing for parts specifi ed with wider operating temperature ranges. *The temperature grade is identifi ed by a label on the shipping container. Consult LTC Marketing for information on non-standard lead based fi nish parts. For more information on lead free part marking, go to: http://www.linear.com/leadfree/ This product is only offered in trays. For more information go to: http://www.linear.com/packaging/
CONVERTER CHARACTERISTICS The
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. (Note 4) PARAMETER CONDITIONS MIN TYP MAX UNITS
Resolution l 14 Bits (No Missing Codes) Integral Linearity Error Differential Analog Input (Note 5) l –6 ±1 6 LSB Differential Linearity Error Differential Analog Input l –1 ±0.5 1 LSB Offset Error (Note 6) l –15 ±2 15 mV Gain Error External Reference l –3 ±0.5 3 %FS Offset Drift ±10 μV/°C Full-Scale Drift Internal Reference ±30 ppm/°C External Reference ±5 ppm/°C Transition Noise SENSE = 1V 1 LSBRMS 2246hfb 2
