Datasheet LTC2271 (Analog Devices) - 4
Description16-Bit, 20Msps Serial Low Noise Dual ADC
Pages / Page24 / 4 — DYNAMIC ACCURACY. The. denotes the specifi cations which apply over the …
File Format / SizePDF / 410 Kb
DYNAMIC ACCURACY. The. denotes the specifi cations which apply over the full operating temperature range,
DYNAMIC ACCURACY The denotes the specifi cations which apply over the full operating temperature range,
LTC2271
l
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. AIN = –1dBFS. (Note 5) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
SNR Signal-to-Noise Ratio 1.4MHz Input 84.1 dBFS 5MHz Input l 82.3 84.1 dBFS 30MHz Input 83.8 dBFS 70MHz Input 82.7 dBFS SFDR Spurious Free Dynamic Range, 2nd Harmonic 1.4MHz Input 99 dBFS 5MHz Input l 88 98 dBFS 30MHz Input 98 dBFS 70MHz Input 90 dBFS Spurious Free Dynamic Range, 3rd Harmonic 1.4MHz Input 99 dBFS 5MHz Input l 88 98 dBFS 30MHz Input 98 dBFS 70MHz Input 96 dBFS Spurious Free Dynamic Range, 4th Harmonic or Higher 1.4MHz Input 110 dBFS 5MHz Input l 93 110 dBFS 30MHz Input 105 dBFS 70MHz Input 100 dBFS S/(N+D) Signal-to-Noise Plus Distortion Ratio 1.4MHz Input 83.9 dBFS 5MHz Input l 81.8 83.9 dBFS 30MHz Input 83.7 dBFS 70MHz Input 82.0 dBFS Crosstalk 10MHz Input –110 dBc
INTERNAL REFERENCE CHARACTERISTICS The
l
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. (Note 5) PARAMETER CONDITIONS MIN TYP MAX UNITS
VCM Output Voltage IOUT = 0 l 0.5 • VDD – 25mV 0.5 • VDD 0.5 • VDD + 25mV V VCM Output Temperature Drift ±25 ppm/°C VCM Output Resistance –600μA < IOUT < 1mA 4 Ω VREF Output Voltage IOUT = 0 l 1.230 1.250 1.270 V VREF Output Temperature Drift ±25 ppm/°C VREF Output Resistance –400μA < IOUT < 1mA 7 Ω VREF Line Regulation 1.7V < VDD < 1.9V 0.6 mV/V
DIGITAL INPUTS AND OUTPUTS The
l
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. (Note 5) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS ENCODE INPUTS (ENC+, ENC–) Differential Encode Mode (ENC– Not Tied to GND)
VID Differential Input Voltage (Note 8) l 0.2 V VICM Common Mode Input Voltage Internally Set 1.2 V Externally Set (Note 8) l 1.1 1.6 V VIN Input Voltage Range ENC+, ENC– to GND (Note 8) l 0.2 3.6 V RIN Input Resistance See Figure 10 10 kΩ CIN Input Capacitance (Note 8) 3.5 pF 2271f 4
